magic
How to distribute /19 with new route package
Tue Apr 11, 2006 7:13 pm
How can I distribute a /19 network to my partners with the new routing package? In the old one I used Networks, but this is missing in the new one.
Krisz
dfwair
Sat Apr 15, 2006 12:20 am
Magic,
The only way I have found to do this so far is to put another router at the head end, and set BGP to statically route the full /19 to the router that you are currently distributing the subnets from. You will need to get another block that you are not announcing from your current ISP.
This is, like I said, one way to do it. I am hoping that we can find a better answer shortly.
changeip
Sat Apr 15, 2006 12:41 am
Assign the /19 to a null interface and then setup the filters to announce it. We have been doing this since 2.9.6 without problems.
Sam
dfwair
Sat Apr 15, 2006 12:44 am
That does seem to work just fine in standard BGP cases, just not in multihop cases. I know I am probably the only one running multihop and running into this issue. :)
changeip
Sat Apr 15, 2006 12:47 am
We run multihop in this fashion - although its on 2.9.7. TTL is 6, multihop is yes.
Sam
Users browsing this forum: Google [Bot], MSN [Bot] and 80 guests
