scooby
USB to USB
Thu Nov 07, 2013 5:57 am
So the newer routers are all coming with a USB connector instead of a serial port. My laptop has never had a serial port. I have a USB to Serial adapter that I use to connect to all my RB4xx series devices. Do I now need 2 USB to Serial adapters to connect my laptop to a MikroTik router with a null modem between them or is there a more graceful way to connect my laptop to one of the newer routers that only provide a USB interface?
Rudios
Forum Veteran
Forum Veteran
Re: USB to USB
Thu Nov 07, 2013 8:13 am
I don't think this will work.
The USB interface on the RouterBoards is only meant for flash drives, so they can be used as storage for logging or proxy.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
ohara
Re: Odp: USB to USB
Thu Nov 07, 2013 8:19 am
also for gsm modem connection.
scooby
Re: USB to USB
Thu Nov 07, 2013 11:37 pm
The Mikrotik DOES support putting a console on a USB serial port:
http://wiki.mikrotik.com/wiki/Manual:Port
Serial and USB ports can also be used to:
connect 3G modems;
connect to another device through a serial cable
access device connected to serial cable remotely.
http://wiki.mikrotik.com/wiki/Supported ... l_adapters
...My question is, is there a more graceful solution than 2 USB to serial adapters with a null modem in between? Does anyone sell a single USB to USB cable with serial ports and null modem embedded into the molded connector or something?
scooby
Re: USB to USB
Thu Nov 07, 2013 11:46 pm
Hrmmm....
This has promise: http://www.amazon.com/GearMo%C2%AE-3-3v ... pd_sim_e_8
...Now just to buy 2 of them and wire them together inline as a null modem...
Users browsing this forum: No registered users and 48 guests
