Stillhard
Changelog RouterOS 6.7
Sun Nov 10, 2013 12:45 am
Changelogs for upcoming RouterOS 6.7
  • What's new in 6.7rc1 (2013-Nov-08 15:54):
    *) fixed hairpin nat on bridge with use-ip-firewall=yes;
honzam
Re: Changelog RouterOS 6.7
Tue Nov 12, 2013 6:04 pm
What's new in 6.7rc1 (2013-Nov-15 10:45):
*) userman - fix crash on tilera;
*) fixed vlan on bridge after reboot having 00:00:00:00:00:00 mac address;
*) address-list - allow manually adding timeoutable entries;
*) address-list - show dynamic entry timeout;
LAN, FTTx, Wireless. ISP operator
Stillhard
Sat Nov 16, 2013 6:23 am
  • What's new in 6.7rc1 (2013-Nov-15 15:23):
    *) ipsec - fix policy bypass on IPv6 gre, ipip, eoip tunnels;
kometchtech
Wed Nov 20, 2013 10:49 am
6.7rc1 version up in November 19? It seems to use, but do you know What changes?
Best regards
Routerboard Users Group JP
http://www.rb-ug.jp/
CCR1009-8G-1S-1S+, RB750Gr3, CRS226-24G-2S+, RB850Gx2, RB960PGS, CRS317-1G-16S+,
RB2011UAS, CRS125-24G-1S, RB962UiGS-5HacT2HnT, CRS212-1G-10S-1S+, RB3011UiAS
armandfumal
Thu Nov 21, 2013 11:26 pm
What's new in 6.7rc1 (2013-Nov-20 14:13):
*) dhcpv4 server - added REMOTE_ID option variable for relayed packets;
*) ipsec - fix policy bypass on IPv6 gre, ipip, eoip tunnels when policy uses protocol filter;
Armand Fumal
________________________________________________________________
MikroTik & Ubiquity
kometchtech
Fri Nov 22, 2013 10:50 am
Thanks!
TonyJr
Fri Nov 22, 2013 6:07 pm
What's new in 6.7rc2 (2013-Nov-22 15:45):
*) leds - inverted modem signal trigger, now it will trigger when the signal level rises above the treshold;
*) ipsec - added sha256 and sha512 support;
*) ipsec - proposal defaults changed to aes-128 and sha1 for both phase1 and phase2;
*) certificate - support ip, dns and email subject alternative names;
D1M0N
Sat Nov 23, 2013 5:19 pm
Where can I download 6.7rc2 ???
RB951G-2HnD
kometchtech
Mon Nov 25, 2013 3:11 pm
What's new in 6.7 (2013-Nov-25 10:22):
maxiscool
Tue Nov 26, 2013 10:10 am
Do we know when 6.7 will be release?
Thanks.
janisk
Tue Nov 26, 2013 10:28 am
there is no release date set.
also 6.7rc2 has some special ppp patches, look more here regarding 6.7rc2
http://forum.mikrotik.com/viewtopic.php?f=2&t=79166&
honzam
Tue Nov 26, 2013 4:03 pm
What's new in 6.7 (2013-Nov-26 09:57):
*) poe - new poe controller firmware for RB750UP and OmniTIK UPA;
what changes?
janisk
Tue Nov 26, 2013 4:35 pm
it should be more precise and report proper values as there where issues observed that sometimes unrealistic reading was displayed.
willy
Wed Nov 27, 2013 4:59 am
Sorry for a possible many asked question, but generally available anywhere the development releases of routeros? My devices affected in a bug in 6.6 (vlan on bridge), and i will be try, but also useful for "advanced" users used with caution. If not accessible generally, please give me download link for 6.7rc1. Thanks.
honzam
Wed Nov 27, 2013 9:23 am
write to support for acceess to prerelease page
dadaniel
Wed Nov 27, 2013 2:19 pm
could you please comment on the following questions:
which max. initial PoE current is possible with the current hardware/firmware?
which protection is built in and is it reversible/replaceable?
thank you very much!
janisk
Wed Nov 27, 2013 2:56 pm
as far as it should concern end-users - it is as before. Also, fw upgrade procedure is simplified.
Malosa
Wed Nov 27, 2013 6:28 pm
There is a bug with PPPoE client in RouterOS 6:
http://forum.mikrotik.com/viewtopic.php?f=2&t=78875
Basically the <<AC-Name=''>> folder in the request must be sent even if it's empty, like other routers do, but Mikrotik doesn't.
It's very important because some modems cannot be used. And it's an extremely easy bug to correct.
Thank you.
skot
Long time Member
Long time Member
Wed Nov 27, 2013 7:21 pm
Glad to get these features. They show up in CLI but not winbox/webfig.
I don't need any karma... I have Ιησους Χριστος!
armandfumal
Wed Nov 27, 2013 11:09 pm
*) ipsec - added aes-ctr encryption mode;
*) fixed l2mtu changing on CCRs - could cause port flapping;
*) disabling/enabling ethernet ports did not work properly on CCRs - could cause port flapping;
Armand Fumal
MikroTik & Ubiquity
honzam
Thu Nov 28, 2013 2:53 pm
What's new in 6.7 (2013-Nov-28 12:53):
*) support Android usb tethering interface;
*) ipsec - added aes-gcm icv16 encryption mode;
*) wireless - improve rate selection for nstreme protocol
*) fixed port flapping on CCR - could happen when having other than only-hardware-queue interface queue.
Note that having other interface queue than only-hardware-queue dramatically reduces performace, so should be avoided if possible;
macgaiver
Thu Nov 28, 2013 3:09 pm
This is interesting - so basically if you have any queue tree and /interface queue isoverrided by it you can also might be affected by this issue....
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
fernandolcx
Fri Nov 29, 2013 3:33 am
This is what I'm talkig about!
kometchtech
Fri Nov 29, 2013 4:34 pm
What's new in 6.7 (2013-Nov-29 13:37):
ckgth
Sat Nov 30, 2013 9:58 am
we have Update an CCR-1036-12G-4S from 6.5 now to testing 6.7 because of port-flapping with 100MB Ports (this was absolutely not acceptable) and now we have "reboot by watchdog timer". With 6.5 this was not! No supout was generated....
Hey MT! I known, the price for this device in resources this have very,very good, but you *must* make Software, who control it good, basically of the standard network processes. I must have an good routing, but no "support for Android". This you can make later....What is with the slogan "Routing the World"?
You wrote in the change-log:
I must think about that you now known this issues? Have you not probe this before you share 6.6 ?
sometimes it is better, to check the software and wait with an release and no release it with failures....
best regards
Christian
normis
Mon Dec 02, 2013 9:10 am
best regards
Christian
Please send your supout.rif file to support. Make the file after you have the reboot problem.
Hotz1
Sun Dec 08, 2013 2:27 am
what changes?
In my brief experience upgrading my test-bench's UPA from 5.26 to 6.7, now a UPA will power two RB411s in ports 2 and 3, but as soon as you try to power a third RB411 in either ports 4 or 5, they all start power-cycling. This is a mess! What happened?!!!
Fortunately, after downgrading back to 5.26, upgrading the PoE firmware put back the older version (2.1), and now it powers all four RB411s with no problem again.
Maybe this is "old news"; I waited until 6.5 before upgrading from 5.26, figuring any major bugs would have been addressed by now. On all the other equipment, 6.5 worked fine, but this is the first PoE-out device I have tried it on. Did this problem start with PoE firmware in 6.0, or are there some 6.x releases that still work?
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
Arpanet
Fri Feb 14, 2014 9:06 pm
Please notice:
command
tls=yes/no
for
/tool email
has changed to
start-tls=yes/no
Arpanet.
There's no distance in the world.
Users browsing this forum: arisk, Baidu [Spider], Sob and 66 guests
