kirlein
mikrotik hotspot with SSL
Fri Nov 22, 2013 11:26 am
i got weird issue when activated HTTPS on hotspot option. people complained that they got "Untrusted Certificate" if typed https domain in url (for first redirect to login page). it showed that dest domain certificate use our SSL certificate , any idea how to fix it ?
kirlein
Re: mikrotik hotspot with SSL
Sun Nov 24, 2013 5:19 am
any1 had experience bout this issue ?
jaykay2342
Location: /Vigor/LocalGroup/Milky Way/Earth/Europe/Germany
Sun Nov 24, 2013 10:38 am
This happen due to the interception of the https connection to facebook. Technical it's a man-in-the-middle "attack" and the router is presenting it's own certificate and the browser is doing what it should do when this happen: show a warning.
9-5 Job: Securityanalyst at a major MSSP.
Free time volunteer: Networkadmin and founder at a small non-profit WISP.
Certifications: ITILv3, GCIA
kirlein
Sun Nov 24, 2013 2:56 pm
yes i know but how to fix it ? is it any way to use HTTPS in hotspot login without got that issue ?
jaykay2342
Sun Nov 24, 2013 3:37 pm
Unfortunately there is no way to "fix" it. if you find a way to "fix" it you find also a way to "hack" https.
boen_robot
Sun Nov 24, 2013 4:03 pm
Maybe if you explicitly send a "511 Network Authentication Required" HTTP status code?
Some older browsers will still have the same problem, but at least new ones may follow the redirect.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
kirlein
Mon Nov 25, 2013 10:55 am
just wondering if we can force https => http when in unauth position.
jaykay2342
Mon Nov 25, 2013 11:58 am
As the http-request is send after the SSL handshake is done i doubt that a browser will its request if it gets an invalid certificate during the handshake.
most probably it terminates the tcp connjection once it's "unhappy" with the certificate.
hasanakgoz
Sun Dec 29, 2013 3:02 pm
Hi;
I have a similar problem. Mobile phones hotspot page does not open. especially the iPhone. A workaround solution yet?
Users browsing this forum: eworm, hivr, sindy and 67 guests
