Raice
Log is flooded with "system, info address changed"
Sat Nov 23, 2013 7:59 am
Hello!
After upgrade to 6.6 log is constantly flooded with message "system, info - address changed"
What does it mean? How to get rid of it?
Screenshot from winbox is attached
Raice
Re: Log is flooded with "system, info address changed"
Fri Nov 29, 2013 1:23 am
Help, please. The log is completely useless now :(
soulflyhigh
Fri Nov 29, 2013 9:38 am
Well, does it really changes or doesn't?
Could you post export of your configuration (mask public ip and/or other sensitive information)?
Regards,
M.
MTCRE, MTCTCE
Raice
Fri Nov 29, 2013 4:18 pm
Here is my config
# nov/29/2013 22:11:44 by RouterOS 6.6
# software id =
add admin-mac=D4:CA:6D:4C:90:E5 auto-mac=no l2mtu=2290 name=bridge-local \
    protocol-mode=rstp
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
    20/40mhz-ht-below disabled=no distance=indoors frequency=2432 \
    ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge ssid=olga \
    wireless-protocol=802.11
set [ find default-name=ether1 ] mac-address=00:26:5A:A5:94:9D name=\
    ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
    ether5-slave-local
/interface pppoe-client
add disabled=no interface=ether1-gateway name=pppoe-orion password=ZZZZZZ \
    user=XXXXXXX
/interface pptp-client
add allow=mschap2 connect-to=111.111.111.111 max-mru=1460 max-mtu=1460 name=\
    pptp-kgsp password="XXXXXXXXXXX" user=XXXXXXXXX
add connect-to=111.111.111.111 max-mru=1460 max-mtu=1460 name=pptp-out1 \
    password=XXXXXXXXXXXXXXXXX user=oph
/interface gre
add disabled=yes keepalive=10 local-address=111.111.111.111 mtu=1200 name=\
    tun-gre-kgsp remote-address=111.111.111.111
/ip neighbor discovery
set wlan1 discover=no
set pppoe-orion discover=no
set pptp-kgsp discover=no
set pptp-out1 discover=no
set tun-gre-kgsp discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
    XXXXXXXXXXXX wpa2-pre-shared-key=XXXXXXXXXXXXX
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5 enc-algorithms=aes-128
add name=default-dhcp ranges=10.195.0.36-10.195.0.62
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
/queue simple
add disabled=yes max-limit=100M/100M name=queue1 priority=1/1 target=\
    192.168.88.249/32,bridge-local total-priority=1
add disabled=yes max-limit=2M/2M name=queue2 priority=1/1 target=\
    192.168.88.250/32,bridge-local total-priority=1
/routing ospf area
add area-id=10.195.0.0 name=kgsp
/routing ospf instance
set [ find default=yes ] redistribute-connected=as-type-1
/system logging action
set 1 disk-file-count=10 disk-lines-per-file=5000
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether2-master-local
add address=192.168.88.1/24 comment="default configuration" disabled=yes \
    interface=bridge-local network=192.168.88.0
add address=10.195.0.33/27 interface=wlan1 network=10.195.0.32
add address=10.195.0.250/30 interface=tun-gre-kgsp network=10.195.0.248
/ip dhcp-client
add add-default-route=no comment="default configuration" dhcp-options=\
    hostname,clientid disabled=no interface=ether1-gateway use-peer-dns=no \
    use-peer-ntp=no
/ip dhcp-server lease
add address=10.195.0.41 client-id=1:0:21:5d:6d:26:bc mac-address=\
    00:21:5D:6D:26:BC server=default
add address=10.195.0.47 client-id=1:4c:8d:79:64:9b:ee mac-address=\
    4C:8D:79:64:9B:EE server=default
add address=10.195.0.32/27 comment="default configuration" dns-server=\
    10.195.0.33 gateway=10.195.0.33 netmask=27
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router
/ip firewall address-list
add address=111.111.111.111 list=extip
add chain=output content="530 Login incorrect" dst-limit=\
    1/1m,9,dst-address/1m protocol=tcp
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input dst-port=53 in-interface=pppoe-orion protocol=udp
add action=drop chain=input dst-port=53 in-interface=pppoe-orion protocol=tcp
add action=drop chain=input comment="default configuration" disabled=yes \
    in-interface=ether1-gateway
add action=drop chain=forward src-address=85.28.118.232
add action=drop chain=input src-address=85.28.118.232
add action=drop chain=input src-address=5.135.36.179
add action=drop chain=input comment="drop ftp brute forcers" dst-port=21 \
    protocol=tcp src-address-list=ftp_blacklist
add action=add-dst-to-address-list address-list=ftp_blacklist \
    address-list-timeout=3h chain=output content="530 Login incorrect" \
    protocol=tcp
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 \
    protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
    address-list-timeout=1w3d chain=input connection-state=new dst-port=22 \
    protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
    address-list-timeout=1m chain=input connection-state=new dst-port=22 \
    protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
    protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
    protocol=tcp
add action=masquerade chain=srcnat out-interface=pppoe-orion
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-address-list=extip dst-port=18090 \
    protocol=tcp to-addresses=10.XXXXXXX to-ports=CCCCCC
add action=dst-nat chain=dstnat dst-address-list=extip dst-port=38570 \
    protocol=udp to-addresses=10.XXXXXXX to-ports=XXXXXX
/ip firewall service-port
set sip disabled=yes
/ip ipsec peer
add address=222.222.222.222 auth-method=rsa-key enc-algorithm=aes-128 key=\
    olga remote-key=kgsp
/ip ipsec policy
add dst-address=333.333.333.333 sa-dst-address=222.222.222.222 sa-src-address=\
    222.222.222.222 src-address=222.222.222.222
/ip proxy
set parent-proxy=0.0.0.0
add distance=1 gateway=pppoe-orion
add distance=1 dst-address=10.169.0.0/24 gateway=pptp-out1
add distance=1 dst-address=10.195.0.0/27 gateway=tun-gre-kgsp
/ip service
set api disabled=yes
/ip upnp
set allow-disable-external-interface=no enabled=yes
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=pppoe-orion type=external
/routing filter
add action=accept chain=ospf-out prefix=10.195.0.32/27
add action=discard chain=ospf-out
/system clock
set time-zone-name=
/system identity
set name=po-home.local
/system logging
add action=disk topics=critical
add action=disk topics=error
add action=disk topics=info
add action=disk topics=warning
add topics=system,debug
/system ntp client
set enabled=yes mode=unicast primary-ntp=59.124.196.85 secondary-ntp=\
    202.131.74.126
/tool mac-server
add interface=wlan1
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
/tool mac-server mac-winbox
add interface=wlan1
/tool sniffer
set filter-ip-address=10.195.0.45/32 filter-stream=yes streaming-server=\
    10.169.0.10
npero
Fri Nov 29, 2013 8:11 pm
Try to remove this topic system,debug from logging.
Raice
Sun Dec 01, 2013 5:12 pm
I added this topic, trying to figure out what is going on
Users browsing this forum: MSN [Bot] and 69 guests
