swissiws
Bonding 2 interfaces - waste of cable?
Wed Nov 27, 2013 5:11 am
hi
I had the idea to bond ether1 & ether2 to get 2Gbit/s between 1 MT1100ah and 1 CRS125 and create InterVLAN at the 1100AH (router on a stick).
Reading about technical design both devices allow only 1Gbit/s throughput towards CPU.
So bonding is a waste of cable and only for utilising fault tolerance?
many thanks!
mrz
Re: Bonding 2 interfaces - waste of cable?
Wed Nov 27, 2013 4:45 pm
If you use ports not on the same switch group then it is not waste of cable.
scampbell
Trainer
Trainer
Wed Nov 27, 2013 10:56 pm
Can you give more detail on how to do this please as the CRS125 has only 1 switch chip whereas RB1100AHx2 has multiple switch chips...does this mean LACP is supported directly to the CRS125 Switch chip
CRS125-131112144104[1].pdf
Block-RB1100AHx2[1].pdf
Users browsing this forum: No registered users and 114 guests
