omberli
Bandwidth limit on Ethernet port
Tue Dec 10, 2013 6:23 pm
I'm trying to figure a routerboard (433 or 751) as a bridge that I want to use to limit bandwidth on the Ethernet port(s). I have (by using Winbox) to set one of the Ethernet interfaces to a max bw (Rx/Tx), but still full bandwidth on all ports (All ports are bridged together). Have also tried to create a simple queue with bw limitations, but still full speed.
Is it possible to set bw limitation in bridge mode?
If so - how?
-Olaf-
c0d3rSh3ll
Long time Member
Long time Member
Re: Bandwidth limit on Ethernet port
Tue Dec 10, 2013 8:25 pm
For use queue feature in a bridge first you need setup enabled use-firewall- bridge in bridge menu.
Send from my mobile phone using Tapatalk.
nothing
omberli
Tue Dec 10, 2013 9:57 pm
Thanks. Tried to enable firewall (filter in the Bridge menu?) (Using Router OS 6.5). Set up a rule "forward" and had ether1 as In and ether2 as Out interfaces (testing on a 433 board). Still full bandwidth through the bridge. Am a bit confused about the diffeent interfaces in this config - bridge, ether1, ether2 etc.
Any more comments.
omberli
Sat Dec 14, 2013 5:36 pm
Am a bit confused. Had some contact with our Mikrotik distributor. They told me that BW control in a bridge isn't possible. The answer here seems to indicate that it IS possible...?
Could someone tell me what to do in order to get BW control in a Mikrotik bridge (Ethernet - Ethernet). If not possible in this config - what is the easiest way to set up BW control in Mikrotik (6.5)?
omberli
Tue Dec 24, 2013 11:27 am
Update.
Finally got this BW limitation working!
The article at
http://wiki.mikrotik.com/wiki/Transpare ... per#Bridge
was very helpful. Didn't have to set up more than a single, simple queue, so the mangle commands were not needed.
The main issue, I think, is that I didn't find the "use firewall" in the Bridge menu. When enabling it via console it worked just fine.
Thanks for your help.
nerdtron
Thu Dec 26, 2013 10:17 am
If it is Ethernet port limiting, you can create a simple queue in winbox to limit the speed per port.
http://www.youtube.com/watch?v=wBVqzYYnAJ8
Users browsing this forum: TheMac and 87 guests
