beejan
FTP multiple logins
Fri Apr 21, 2006 8:21 am
Hai there!
I have successfully enable my ftp server through mikrotik. I did the port forwarding. However i notice that only 1 user can passthrough the mikrotik to open the ftp. How can i enable the mikrotik to allow multiple users login?
thanks! :D
everyday is a bliss..appreciate every moments u have :)
Mapik
Fri Apr 21, 2006 12:16 pm
I think this may help
/ip firewall service-port enable ftp
Gotmoh
Fri Apr 21, 2006 2:45 pm
Realy? It enables internal ftp server on MikroTik IMHO. You dont need this to use ftp inside your LAN.
tneumann
Fri Apr 21, 2006 8:06 pm
Gotmoh, you're confusing this with /ip service, which
indeed controls services on the router itself.
--Tom
valens
Trainer
Trainer
Sat Apr 22, 2006 12:40 am
Check the FTP Server configuration.
I don't think it's the problem on Mikrotik.
If one user can login, it means the D-NAT / Routing / Firewall in Mikrotik correctly configured.
Gotmoh
Sat Apr 22, 2006 9:21 am
--Tom
Me confusing? Or Mapik? :twisted:
Mapik
Sat Apr 22, 2006 10:30 am
--Tom
command
will enable internal ftp proxy in MT, which may help with this problem I hope
beejan
Wed Apr 26, 2006 3:56 am
thanks for the numerous replies guys!! :D i really appreciate it!
Mapik, i have enable the service-port as u said. my ftp is working already.
however...what i want is multiple users to use the ftp at the same time. currently only 1 user can use the ftp. mikrotik does not allow multiple users to use the ftp simultaneously.
is there a way to setup the mikrotik to allow more users using the ftp?
thanks!
Users browsing this forum: abvintranet, sindy and 172 guests
