RikiBez
MikroTik blocks iTunes device's restore
Tue Dec 24, 2013 7:28 pm
I'm new to the forum and also to the MikroTik world.
Our ISP has just installed us a new Optical Fibre connection using a MikroTik as router.
I setted up the wireless connection and opened the default port 80 to manage it from outside.
Last thing to solve is that we can't restore iDevices from this network cause we always have the 3014 error from iTunes. I searched on the Apple forum and it seams an issue related to the firewall that block port connection on 80 and/or 443 (HTTP, HTTPS).
I tried to disable to firewall rule that I created before but the problem still.
Could anyone help me?
Sorry for my bad english. If you need more infos just ask and tell me how to retrieve it :D
Thanks,
Riccardo
c0d3rSh3ll
Long time Member
Long time Member
Re: MikroTik blocks iTunes device's restore
Sat Dec 28, 2013 10:58 pm
Post the output of this command:
ip firewall export
Send from my mobile phone using Tapatalk.
nothing
RikiBez
Sun Dec 29, 2013 1:00 pm
Thanks for your answer c0d3rSh3ll :D
Here is my firewall config exported:
[admin@MikroTik] > ip firewall export
# jan/14/1970 21:01:23 by RouterOS 6.6
# software id = 0N0D-609Z
add chain=input comment="default configuration" protocol=icmp
add chain=input disabled=yes dst-port=22 protocol=tcp
add chain=input dst-port=80 protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=\
    sfp1-gateway
    ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=sfp1-gateway
    out-interface=ether1-gateway to-addresses=0.0.0.0
[admin@MikroTik] >>
I suppose there something wrong with the date and time too :P
RikiBez
Thu Jan 09, 2014 5:21 pm
Any news about my issue? :D
Caci99
Fri Jan 10, 2014 9:49 pm
There does not seem to be any rule blocking your communication. Any way, you can feel safe disabling the firewall filter rules for the purpose of testing it.
-Toni-
Don't crash the ambulance, whatever you do
jmay
Sat Jan 11, 2014 12:36 am
Can you get to the apple app store or iTunes? We had a problem that turned out to be our ip addresses. Apple was blocking them because they thought they were non-us addresses. We resolved this by changing them.
RikiBez
Wed Jan 15, 2014 12:29 pm
The AppStore and iTunes are working fine. We are an Apple Premium Service Provider and I don't think Apple is blocking our IPSs :D
Is it possible that the new ISP is blocking our traffic to that port?
Users browsing this forum: Bing [Bot], Google [Bot] and 64 guests
