Mikro-Man-Tik
2.9.22 released ...
Fri Apr 21, 2006 6:53 pm
What's new in 2.9.22:
*) show detected http-proxy for hotspot hosts;
*) fixed webproxy-test to detect http-proxy for hotspot hosts
(broken in 2.9.12);
*) fixed MAC address changing in Ethernet like interfaces
thnx andrewluck
Last edited by Mikro-Man-Tik on Fri Apr 21, 2006 8:49 pm, edited 2 times in total.
andrewluck
Forum Veteran
Forum Veteran
Fri Apr 21, 2006 8:27 pm
Alessio Garavano
Sat Apr 22, 2006 2:16 am
Opinions? Testings?
Anyone test this release?
Thanks!
Alessio
Alessio Garavano
http://www.isparg.com.ar
oriondotnet
Sat Apr 22, 2006 8:37 am
Yes please....
Anyone testing v2.9.22 ? want to put this 1 into our core router... specially with intel Pro 1000/MT
Alex
Sat Apr 22, 2006 10:40 am
i have found bug with v 2.9.22 and intel pro 1000 gt desktop adapter.all works fine but in winbox interface stats are broken(show wrong information and blink)
Image.
With 2.9.20 all works fine
KimC
Sat Apr 22, 2006 8:01 pm
Same here...
Also, the Intel Gbit adapters are still not correctly recognised in System/Resources/PCI
cdemers
Odd OSPF Behaviour
Wed Apr 26, 2006 12:39 am
Ok, I just want to checak and see if anyone else is having any issues with 2.9.22 with OSPF, being used as primarily a backup. Everything worked fine with 2.9.20 before, everything looked fine with 2.9.22 and I upgraded some of my routers and everything was good. Upgraded the rest and one feature of OSPF seems to not be working. Also unable to equal cost load balance with OSPF which I would do before. I'm using the exact examples in the manual (page 106 aka page 119, last page of OSPF in the PDF file). And I am no longer able to switch the link by adjusting it's cost.
vklimovs
Wed Apr 26, 2006 2:42 pm
Same problem with traffic graphs on Intel Pro 1000 as Alex described.
rpingar
Long time Member
Long time Member
Thu Apr 27, 2006 11:11 am
I builded a new box with a asus p5p800SE and several intel dual gigabit adapter.
Seems thay are not working fine.
They boot ok, but asap I plug two gbit lan inside each intel nic it stops working, the led on the board ges down and I hav only to reboot the router to have the board working again.
Is it experienced by any one else?
Rosairo
normis
Thu Apr 27, 2006 11:33 am
all these problems solved in next release
Mapik
Thu Apr 27, 2006 11:57 am
I have problems with wireless scan on 2.4-GHz, can't see networks. In 2.9.20 it's OK
normis
Thu Apr 27, 2006 12:03 pm
mapik, write to support. something's wrong in your configuration probably. or maybe there simply are no 2.4 devices in your area (is that even possible?)
oriondotnet
Thu Apr 27, 2006 1:35 pm
Rosairo
Hi... I have the same problem also... put dual port intel gigabit card... it get stuck, stop working, I already reboot and still not working... hope this problem solved in the next version
Mapik
Thu Apr 27, 2006 2:45 pm
Ohh, sorry, it was problem with radio card
Users browsing this forum: gogle, Google [Bot] and 224 guests
