What do I want to look at or do next?
EDIT: Updated config dump
Edit2: Updated config dump
ros code
[admin@MikroTik] > export hide-sensitive compact # jan/11/2014 13:44:55 by RouterOS 5.26 # software id = HFLJ-B1QM # /interface ethernet set 0 name=sfp1-gateway set 6 name=ether6-master-local set 7 master-port=ether6-master-local name=ether7-slave-local set 8 master-port=ether6-master-local name=ether8-slave-local set 9 master-port=ether6-master-local name=ether9-slave-local set 10 name=ether10-WAN /interface bridge add admin-mac=D4:CA:6D:6F:6D:F3 auto-mac=no name=bridge-local protocol-mode=rstp add l2mtu=1598 name=FiberOp-bridge protocol-mode=rstp /interface vlan add interface=ether10-WAN l2mtu=1594 name=FiberOp-VLAN vlan-id=35 /interface wireless security-profiles add authentication-types=wpa2-psk eap-methods=passthrough management-protection=allowed mode=dynamic-keys name=THX1138-WPA2 supplicant-identity="" /interface wireless set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above country=canada disabled=no distance=indoors ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge security-profile=THX1138-WPA2 ssid=THX1138 wireless-protocol=802.11 /ip pool add name=InternalPool ranges=192.168.0.105-192.168.0.200 /ip dhcp-server add add-arp=yes address-pool=InternalPool disabled=no interface=FiberOp-bridge name=FiberOp-DHCP /interface bridge port add bridge=FiberOp-bridge interface=ether2 add bridge=FiberOp-bridge interface=ether3 add bridge=FiberOp-bridge interface=ether4 add bridge=FiberOp-bridge interface=ether5 add bridge=FiberOp-bridge interface=ether6-master-local add bridge=FiberOp-bridge interface=wlan1 /ip address add address=192.168.0.1/24 interface=FiberOp-bridge /ip dhcp-client add disabled=no interface=FiberOp-VLAN use-peer-dns=no use-peer-ntp=no /ip dhcp-server network add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1 /ip dns set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4 /ip firewall filter add chain=input comment="Accept Ping" protocol=icmp add chain=input comment="Accept Established" connection-state=established add chain=input comment="Accept Related" connection-state=related add action=drop chain=input in-interface=sfp1-gateway add action=drop chain=input in-interface=FiberOp-VLAN /ip firewall nat add action=masquerade chain=srcnat comment="Hairpin NAT HTTP" dst-address=192.168.0.100 dst-port=80 out-interface=FiberOp-bridge protocol=tcp src-address=192.168.0.0/24 add action=masquerade chain=srcnat out-interface=FiberOp-VLAN src-address=192.168.0.0/24 add action=dst-nat chain=dstnat comment="NAT HTTP" dst-port=80 in-interface=FiberOp-VLAN protocol=tcp to-addresses=192.168.0.100 to-ports=80 /ip neighbor discovery set sfp1-gateway disabled=yes set ether10-WAN disabled=yes set wlan1 disabled=yes set FiberOp-VLAN disabled=yes /ip service set telnet disabled=yes set ftp disabled=yes set www address=192.168.0.0/24 port=8080 set ssh address=192.168.0.0/24 set winbox address=192.168.0.0/24 /system clock set time-zone-name=America/Moncton /system ntp client set enabled=yes primary-ntp=142.4.200.228 secondary-ntp=198.245.49.187 /system ntp server set enabled=yes /tool mac-server add disabled=no interface=ether2 add disabled=no interface=ether3 add disabled=no interface=ether4 add disabled=no interface=ether5 add disabled=no interface=ether6-master-local add disabled=no interface=ether7-slave-local add disabled=no interface=ether8-slave-local add disabled=no interface=ether9-slave-local add disabled=no interface=wlan1 add disabled=no interface=bridge-local /tool mac-server mac-winbox set [ find default=yes ] disabled=yes add interface=ether2 add interface=ether3 add interface=ether4 add interface=ether5 add interface=ether6-master-local add interface=ether7-slave-local add interface=ether8-slave-local add interface=ether9-slave-local add interface=wlan1 add interface=bridge-local /tool sniffer set filter-direction=any
