ste
IPV6 is it usable
Fri Jan 17, 2014 10:33 am
We've now the first Requests for IPV6 which is useful (a snyc SW which does not work on V4).
So we're considering to add official IPV6 to our Service. Anyone has a only MikroTik-Network with
IPV6 running in parallel to IPV4 (BGP/OSPF/...).
Problems?
raz
Re: IPV6 is it usable
Fri Jan 17, 2014 1:35 pm
tried to setup ipv6 with a bgpv4 session, but didnt worked.
ste
Fri Jan 17, 2014 2:05 pm
support@mikrotik.com could not help?
tomaskir
Trainer
Trainer
Sat Jan 18, 2014 11:17 am
We have full ipv6 with ospfv3 deployed in our network, but our upstream only provides us with a statically routed prefix, no ipv6 bgp from our upstream yet.
Overall, there is a few features missing, but what is in, works.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
SwissWISP
Sun Jan 19, 2014 3:13 pm
There seems to be a problem with the Next Hop in BGP, if you use OSPFv3 as IGP. You will see the Next Hop as "unreachable" in the routing table.
You can find some Information in this forum.
- Mat
raz
Mon Jan 20, 2014 8:57 am
Maybe in some Weeks, have to read completly in and try again. After it wont work, ill ask MT
roadracer96
Forum Veteran
Forum Veteran
Tue Jan 21, 2014 10:10 pm
- Mat
Yeah, I just did some testing with it and I had to create a route filter to set the next hop based on the peer. It is setting the next hop to the link local up of the far end peer in multi-hop instead of inheriting the next hop from the static route to the bgp peer.
zimage
Thu Apr 17, 2014 10:43 pm
[/quote]
Could you expand on this with an example of your route filter? I've been banging my head on this lack of recursive next hop lookup, OSPFv3, BGP problem for months.
Users browsing this forum: Google [Bot], poizzon and 103 guests
