MUM Europe 2020
Makoto
Core router options
Thu Jan 30, 2014 11:19 am
Hi all!
I have been reading and searching but just in case I woud like few pointers pl so I dont buy cat in the bag :) !
My ayes are stuck on RB1100ahx2 for core router for small wisp project!
RB woud have to handle: -
PPPoE max 200 conections with user-manager
- Firewall
- QoS
- logging users activities (for starters on SD 16gig disk , to bad there is no RB product with sata disk possibility :( )
- No more then 50-60 Mbits of trafic form WAN to bridge network!
Basically I woud like to do evrything with one box, no extra servers and devices at least for now !
Woud this device do the job ?
Thx !
zyzelis
Re: Core router options
Thu Jan 30, 2014 1:57 pm
Hi all!
- Firewall
- QoS
Thx !
Hello Makoto,
you not wrote what speeds will be assigned to clients.
With my experience 1100AHx2 will not handle 200 users with shaping. it crashes when load reaches 50mbit/s
You should look to CCR.
nz_monkey
Thu Jan 30, 2014 8:19 pm
Hello Makoto,
+1
I definitely agree, the CCR is better than the RB11xx series in every way.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
Makoto
Thu Jan 30, 2014 9:15 pm
Thx for advice so I am left to go with CCR or some x86 custom thing !
Makoto
Fri Jan 31, 2014 10:33 am
Thx for tips , I whill look into CCR and other options.
16 core model should be sufficient ? I whant to get good thing but at the same time be careful with my budget :) .
ste
Fri Jan 31, 2014 11:07 am
A router for 200 PPOE-Sessions is a central component. You should plan enough Budget for it.
So go with the bigger CCR as it is cheap anyway. If you have to argue get the pricing for a juniper/cisco.
Users browsing this forum: No registered users and 89 guests
