aliwishstar
hotspot user disconnect after 5 min
Thu Feb 20, 2014 4:40 am
hi all
i have problem with hotspot user on mikrotik(5.26) with free radius.
problem:users disconnect after 5 min even through they downloading file.
solution
i changed profiles
user profile hotspot(config)
idle time out:01:30:00
keep alive timeout :01:30:00
session idle time out:01:30:00
server profile
radius
interim update : 00:01:00
cookie enable and time :01:30:00
using pap & chap together in client authentication request.
anyway,i change all setting to none,zero,or disable it.
i used this setting now
name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
name="hsprof1" hotspot-address=192.168.88.1 dns-name="hp.domain.local" html-directory=hotspot rate-limit=""
http-proxy=192.168.88.1:8080 smtp-server=0.0.0.0 login-by=cookie,http-chap,http-pap http-cookie-lifetime=1h30m
split-user-domain=no use-radius=yes radius-accounting=yes radius-interim-update=1m nas-port-type=wireless-802.11
radius-default-domain="" radius-location-id="" radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:X
please help how can i fix this problem?
thanks again
aliwishstar
Re: hotspot user disconnect after 5 min
Fri Feb 21, 2014 11:06 pm
cant any one help me?
nerdtron
Sun Feb 23, 2014 4:14 pm
What is your session timeout in freeradius?
Also just to make sure that there is no limit on the time, login a user and then view the Active tab on the IP>Hotpspot.
If you see it countdown, then you have a setting for session timeout.
Users browsing this forum: fusa, Google [Bot], sindy and 99 guests
