tabate47
How do I send an email to 2 addresses in Netwatch Script?
Sun Mar 02, 2014 8:02 am
Right now I am sending an email to myself. I need the email to also go to another address. Is there a way to set it up so that the notification email will go to two separate addresses?
Thanks.
SurferTim
Re: How do I send an email to 2 addresses in Netwatch Script
Sun Mar 02, 2014 12:02 pm
You should be able to send as many as you want. You are using a script to send the current email, correct? Just add another send to that script.
tabate47
Sun Mar 02, 2014 8:35 pm
Here is my script:
/tool e-mail send to= mikrotik@***.com subject=([/system identity get name] . " Printer Up")
It's in the up portion of the netwatch. How would I add another address?
SurferTim
Sun Mar 02, 2014 8:38 pm
/tool e-mail send to= anotheruser@***.com subject=([/system identity get name] . " Printer Up")
tabate47
Sun Mar 02, 2014 9:00 pm
Wow that's too easy. I'll try it. Thanks.
marioclep
Trainer
Trainer
Wed Mar 05, 2014 1:12 am
/tool e-mail send to=first@email.com cc=second@email.com subject=test body=test
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
tabate47
Wed Mar 05, 2014 8:35 am
Mike how would that work with more than 2 emails?
Users browsing this forum: Bing [Bot], eg29, eworm, jvanhambelgium, pierpa77 and 70 guests
