fredbred
Secure connection Mikrotik - Winbox
Fri May 05, 2006 5:32 pm
Hi, i am trying to set up a secure connection to manage my routers via winbox.
The connection from winbox itself is not secure and the pass and user can be compromised. Which any possibility have i to protect my connection to router. i am connecting allways over an ethernet interface.
i have not much experience with ipsec or vpn yet.
please post any suggestions.
thnx
changeip
Fri May 05, 2006 7:59 pm
With 2.9 and the security package it should use port 8291 by default. This will make things encrypted. You can also append :8291 to the hostname and it will try that first, if it doesn't already.
aitsecurity
Re: Secure connection Mikrotik - Winbox
Fri May 05, 2006 11:59 pm
thnx
mmm, i wake up my ethereal sniffer, and make a winbox connection, and is encrypted, but i only see in ascii the library example router.dll, proxy.dll,etc when winbox is running, i was get system resource, and stop the sniffer, and the information from my routeros to my laptop is encrypted.
now, is do you want more, you can make a VPN and run the winbox inside.
i am thinking the winbox is very secure socket,
Best Regards
fredbred
Sun May 07, 2006 9:47 am
my pass has been compromissed by my colleague and he told me, that he was sniffering my ip and that could get my pass during logon. But now i thing he used another way - trought my local stored pass for winbox and my local machine was not secured enought.
i will update this next week.
thnx
fredbred
Wed May 10, 2006 8:58 am
thnx for your support. It realy seem that my pass was compromissed trought local stored config. Next time i have to remember all my pass :-(
But maybe it would also be a good idea not to store the connection config as plain text.
thnx aitsecurity & changeip
Users browsing this forum: achu, bpwl, eworm, jp83, Kindis, planetcoop, Trezona and 87 guests
