azurtem
Trainer
Trainer
router as switch ?
Fri Mar 07, 2014 3:17 pm
Hi
I am designing a wireless network for a client.
Generally when I cable a client's premises for a wireless network
I have Ethernet back haul cables from each PoE AP all hooked up
to a central switch down in the basement
But in this case I'm looking at 7 Poe APs per floor, that's 35 APs
across 5 storeys. So I guess I'm going to use a switch per floor
this time.
In my desire to put Mikrotik everywhere at first I wanted to use
an RB2011 as switch on each floor; what a pity that only half the
ports are Gigabit Ethernet capable.
I'll also have to use the passive PoE adapters for each switch
connection right ? Does Mikrotik have a fully passive PoE capable
(on all ports) switch yet ?
I also forget that these are routers, not switches. Does it seem
overkill to use the RB in this manner ? Rather than a standard
switch e.g. TP-Link ?
Thanks for your opinions & recommendations
yann
efaden
Re: router as switch ?
Fri Mar 07, 2014 3:21 pm
Hi
this time.
yann
260GSP is coming out soon. 5 Port POE Gigabit with SFP.... nothing bigger with POE. If you want to get bigger you could either get two or get one of those 12 port passive POE units and put something like a CRS on it it.
See: http://wifiqos.com/
mmv
Trainer
Trainer
Sat Mar 15, 2014 2:51 pm
If 100 Mbit is enough as uplink for 4 AP, then RB750UP can be good solution.
Mikhail Moskalev
efaden
Sat Mar 15, 2014 3:08 pm
I think two of those 260GSPs connected via a direct SFP cable would work nicely...
You would get 5 ports per 260. So a total of 9 usable ports per set (1 as the trunk to the floor) and then the SFP to connect the two units together.
-Eric
azurtem
Trainer
Trainer
Sat Mar 15, 2014 4:46 pm
thanks for your replies
I have actually turned my attention to Ubiquiti's ToughSwitch
which is an 8 port passive POE switch :
http://dl.ubnt.com/datasheets/toughswit ... PoE_DS.pdf
efaden
Sat Mar 15, 2014 4:50 pm
That would work also. I actually run one of their 5 Port ones at one site. They are pretty nice.
Users browsing this forum: Bing [Bot], cj3666, Google [Bot], i4jordan, McSee, wtechlink and 166 guests
