MUM Europe 2020
Arpanet
Netwatch issue
Wed Mar 12, 2014 7:50 pm
I set up netwatch on my RB750GL successfully.
But I notice it works only if dsl-modem turns off.
So whenever modem loses dsl-alignment or internet connection I cannot know anything.
Why does this happen?
Is there a way to "watch" even those parameters?
thanks
Arpanet.
There's no distance in the world.
headshoter
Re: Netwatch issue
Wed Mar 12, 2014 9:02 pm
in case u r using for failover :
/ip route add dst-address=8.8.4.4 gateway=FISRT MODEM IP
/ip route add dst-address=4.2.2.2 gateway=SECOND MODEM IP
then you should watch 8.8.4.4 and 4.2.2.2 and ...
Arpanet
Re: Netwatch issue
Wed Mar 12, 2014 9:07 pm
two modems? I'm not using failover
my rb750gl has to "watch" only one modem
Arpanet.
headshoter
Re: Netwatch issue
Thu Mar 13, 2014 6:36 pm
would you please give me more information ?
why you use netwatch ? ...
Arpanet
Re: Netwatch issue
Sat Mar 15, 2014 6:25 pm
The two modems have to be in the same ip network, correct?
Arpanet.
headshoter
Re: Netwatch issue
Fri Mar 21, 2014 11:52 am
i can not get clear about what you gonna do , but
im thinking your problem is you are watching your modem ip (for example 192.168.1.1) instead of something like 8.8.8.8.
Users browsing this forum: dad2312, Filament and 112 guests
