MUM Europe 2020
alsam
Gateway outside IP subnet
Fri Mar 14, 2014 8:45 pm
I am trying to use my Mikrotik with a Thomson TG782 gateway. I set the TG782 to assign the public IP address to the Mikrotik, which it does successfully. However, the IP address assigned is 64.xxx.xxx.xxx/8 and the gateway is 173.xxx.xxx.xxx. Because of this, the Mikrtotik has no gateway to use. This configuration somehow works in the Thomson through PPPoA voodoo :) Is there a workaround to have this work on my Mikrotik? Thanks in advance for any and all help.
alsam
Re: Gateway outside IP subnet
Fri Mar 28, 2014 5:26 pm
Anyone care to take a stab at this?
alsam
Sun May 04, 2014 10:43 pm
Anyone?
ScottReed
Tue May 06, 2014 8:12 pm
This Thompson device, is it setup to terminate a PPPoE or PPPoA with a DSL provider?
Is it setup as a bridge (non-router mode)?
On your Mikrotik router, please ensure that your DHCP client is configured to "Add Default Route" set to YES. Make sure the DHCP Client is configured on the interface that is uplinked to the Thompson.
Please send me the following output:
1. /ip dhcp-client print
2. /ip address print
3. /ip route print
Scott
IPANetEngineer
Trainer
Trainer
Tue May 06, 2014 9:20 pm
Try routing it out the interface rather than the IP gateway
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Users browsing this forum: Google [Bot], odalsoft, rioven and 82 guests
