DanielJB
Enable TCP ECN for bandwidth efficiency
Thu Mar 20, 2014 7:48 am
We need a way to enable TCP Explicit Congestion Notification on RouterOS, so when eg TCP tunnels are established, we will get the increase in efficiency and reduction in packet loss. The current linux default is to accept ECN, but not request it when initiating connections.
Thus, we need a config option to do this:
echo 1 >/proc/sys/net/ipv4/tcp_ecn
A good candidate for RouterOS 7.
Chupaka
Re: Enable TCP ECN for bandwidth efficiency
Fri Mar 21, 2014 11:06 pm
I'd rather say, a good candidate for 'IP -> Settings' in RouterOS v6.12 =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
DanielJB
Sat Mar 22, 2014 11:50 am
Indeed. With a significant number of competing TCP flows, Zheng and Kinicki demonstrate a 15% improvement in goodput (ie useful TCP segments, flow efficiency) through an ECN-capable router, page 15:
http://web.cs.wpi.edu/~rek/ISCC02talk.ppt
Anyway, let me know if anything more is needed to submit this as a feature request for RouterOS. Many thanks!
Chupaka
Mon Mar 24, 2014 8:51 am
write to support@mikrotik.com for an answer
Zorro
Long time Member
Long time Member
Tue Aug 02, 2016 9:24 am
any chance to see update/implementation on-topic ?
even w/o say PURPLE queues ( f-GREEN and s-GREEN are not ECN-dependant) there was TOO much tech in modern networking that fail to work or Severely underperfrom w/o ECN support(both support, requence, enforcement, enabled/toggled in all kinds/points of gear/networks).
its rather "simple update" to ROS, not demanding newer kernel or newer code, just extra checkbox(like say "routing cache" enabling or one for "syncookie" or for "RP Filter"(if MT decide to implement all 3 options for)in option for ROS to be aware in bootime about dat option/switch to perform according to. so there was no need to wait for ROS7 or much manpower/hours of work needed i suppose.
for anyone new to topic:
https://en.wikipedia.org/wiki/Explicit_ ... tification
https://tools.ietf.org/html/rfc3168
as basic introduction.
same about "enabling/disabling timestamps" - sometimes they Should be disabled, sometimes they are Lifesavers so there was "always should option about" such things in general.
omidkosari
Trainer
Trainer
Wed Sep 21, 2016 3:33 pm
Any news about ECN support ?
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
pe1chl
Wed Sep 21, 2016 5:27 pm
It would be more interesting to know (as these are routers) which queue types, if any, support ECN
in MikroTik products.
vomacko
Sat May 20, 2017 11:01 am
Any news on ECN topic?
Joni
Tue Dec 18, 2018 9:06 pm
https://wiki.mikrotik.com/wiki/Manual:I ... all/Filter
bluecrow76
Fri Jan 25, 2019 7:03 pm
Being able to set the ECN flag is a much different thing than knowing whether or not a queuing mechanism supports setting and receiving the ECN flag inherently. Just being able to set the flag on an outbound packet doesn't mean that a router "supports ECN." True ECN support would mean the queuing mechanism would slow the transmission of data when it observed a packet with the ECN flag set, rather than dropping packets.
Users browsing this forum: Baidu [Spider], rjscomms and 93 guests
