MUM Europe 2020
trn76
IPSec Tunneling - Help needed! Will pay for the job...
Thu Mar 20, 2014 6:18 pm
I need help setting up an IPSec Tunnel, where I've got all info regarding setting it up.
There are several routes(IP addresses) that need to go throu the tunnel, the rest shall use the default gateway.
I've done 90% of the job, what is missing is last part of IPSec Phase2 - I can see both Installed ASs, but only me sending (no data on recieve)... So there are some NAT issues that I'm not able to figure out.
...Help is needed, guess the job should take about an hour.
Please contact me if you are up for it, I can pay you for the job (we will be using TeamViewer).
The sooner, the better... Thanks 8)
efaden
Re: IPSec Tunneling - Help needed! Will pay for the job...
Thu Mar 20, 2014 6:23 pm
I can help. Drop me an email.
trn76
Thu Mar 20, 2014 6:53 pm
Check you email ;)
onyx3821
Mon Mar 24, 2014 6:28 pm
OK So any hints ? I'm stuck in an ipsec boat... Getting installed SAs during the transmission but no traffic passing...
Thanks,
Rick Smith, Network Engineer
rsmith@navitend.com | www.navitend.com
P (973) 448 0070 | F (973) 448 0264
23 US Highway 206 Byram Twp. NJ 07874
efaden
Tue Mar 25, 2014 6:33 pm
Start a new thread and post your problem and export.
This is a fairly specific case which isn't actually possible.
Users browsing this forum: durrsaku, nemoforum, shahani and 105 guests
