MUM Europe 2020
2frogs
Long time Member
Long time Member
RB2011UAS-2HnD issues after v6.11 update
Sat Mar 22, 2014 7:41 pm
After some time my RB2011 is losing interfaces. A reboot will bring them back, but again they will disappear. Even with those interfaces not appearing, most functiona are still operating normally. I only noticed this because of an AirRouter that I use as a repeater was no longer connecting. Here is a list of things i noticed:
Wireless Interface:
wlan1- was not present (it was still allowing clients to connect and passing traffic)
vap-wlan3- was not present, Master Interface is wlan1
vap-wlan2- was preset with corresponding wds1 even though it's Master Interface is wlan1 (this AP is used with the AirRouter)
Bridge:
MainBridge - Not present and bridge-ports showed "unknown" for their associated bridge
UBNT - Not present (normally unused)
Addresses:
Address for MainBridge, the router normal IP, showed "unknown" for interface
Address for vap-wlan3 also showed "unknown" for interface
2 seperate wan addresses where not present at all, these are both dhcp-clients
These are the only things that i noticed. The first time I saw this issue, I created a new Bridge interface and added just one of the ports to it and all of sudden the other Bridge interfaces reappeared. I rebooted after changing the port back to it's original and deleting the newly created Bridge interface.
I have screen shots that show these error, if you like for me to post them and supout file.
Dudshl
Re: RB2011UAS-2HnD issues after v6.11 update
Wed Apr 02, 2014 5:31 am
I have same issue. It happens 1-2 times every day.
RB2011, Got problem after 6.11 upgrade
jarda
Wed Apr 02, 2014 6:12 pm
Try to export config, remove all settings and run config script back.
Users browsing this forum: No registered users and 87 guests
