arainbow
CAPsMAN work only layer2 [Solved]
Wed Mar 26, 2014 4:33 am
CAPsMAN work only layer2, can't work on IP address. stop at datacheck.
uldis
Re: CAPsMAN work only layer2
Wed Mar 26, 2014 10:05 am
CAPsMAN can connect also on Layer3 via IP.
Here look up in the manual how it is working:
http://wiki.mikrotik.com/wiki/Manual:CA ... Connection
If you still see error enable the caps,debug logging on the CAPsMAN and wireless,debug logging on the CAP and make a support output files from both and send them to support@mikrotik.com
arainbow
Sun Mar 30, 2014 10:10 pm
if ipv6 package is enabled, then use ipv6 address can connect to capsman, ipv4 address not work.
if ipv6 package is disabled, use ipv6 address can connect capsman.
siscom
Sun Mar 30, 2014 10:15 pm
Hi arainbow,
Is this fact, opinion or a bug? We have yet to implement ipv6!!
Just asking, really!
Rgds,
Mark.
denser
Fri Dec 12, 2014 10:38 am
Yes, confirm. I set ap CAP:
/interface wireless cap print
                            enabled: yes
                         interfaces: wlan-lan
                        certificate: none
                   lock-to-caps-man: no
               discovery-interfaces:
                 caps-man-addresses: 192.168.0.250
                     caps-man-names:
  caps-man-certificate-common-names:
                             bridge: bridge-local
and logs says:
dec/12/2014 15:17:49 caps,debug CAP Select->Sulking
dec/12/2014 15:17:54 caps,debug CAP Sulking->Discover
dec/12/2014 15:17:54 caps,debug CAP discovery target list:
dec/12/2014 15:17:54 caps,debug   ::ffff:192.168.0.250:5246
dec/12/2014 15:17:57 caps,debug CAP discovery over, no results
dec/12/2014 15:17:57 caps,debug CAP Discover->Select
dec/12/2014 15:17:57 caps,debug CAP did not find suitable CAPsMAN
uldis
Fri Dec 12, 2014 12:34 pm
denser,
What RouterOS version you are using and are you using CAPsMAN v1 or v2?
denser
Fri Dec 12, 2014 3:29 pm
I use capsman v2 (i need to auotoupgrade feature) and ROS 6.22 and 6.23(find update today and try it)
On both versions same result. Capsman 1 wont use cose of no upgrade ability.
uldis
Fri Dec 12, 2014 5:01 pm
please install v6.23 and report support output files from capsman v2 system (capsman and cap) to support@mikrotik.com
denser
Mon Dec 15, 2014 4:15 am
After upgrading to 6.23 cap and capsmanv2 - nothing change. Log tells me same picture. Send supout from both systems to support.
Hope to get fix it ASAP :) Thx.
denser
Tue Dec 16, 2014 5:07 am
Thx to Uldis! We solved this problem. CAPsMANv2 6.23 (may be earlier too) works via ipv4 address with one thing - need routes between networks in both side and opened ports on CAPsMAN 5246,5247/udp
I think it should be on wiki.
efaden
Re: CAPsMAN work only layer2 [Solved]
Tue May 26, 2015 3:38 am
Did anything ever come out of the IPv6 problem? I am having a similar problem. Two basically clean boxes...
1 has IPv6 enabled... the other doesn't. CAPsMan won't connect between them. If I disable IPv6 it works fine. Thoughts? This is all on 6.28
uldis
Tue May 26, 2015 10:10 am
Please email support output file from CAPsMAN and CAP to support@mikrotik.com with the steps how to repeat this problem.
ploquets
Sat Apr 08, 2017 4:12 pm
Yes.
For those who are running CAPSMANAGER and CAP at the same router, should create firewall rules INPUT.
add action=accept chain=input comment="CAPSMANAGER Discovery" protocol=udp src-port=5246,5247
add action=accept chain=input comment="CAPSMANAGER Discovery" protocol=udp dst-port=5246,5247
Even working on Layer2 (with no IP configured at CAP settings [CAPsMAN Addresses] )
We needed to create this for Discovery to work
Users browsing this forum: Baidu [Spider], yuridee and 104 guests
