MUM Europe 2020
hci
Long time Member
Long time Member
CCR 100 Percent CPU
Tue Apr 01, 2014 2:31 am
Running v6.11 on my CCR routers. My heaviest loaded routers are a PPPoE server and another is a BGP core router. Both seem to list one CPU core at 100 percent CPU usage 24/7. I cant help but wander if neither PPP or BGP is capable of using multi-cores?
normis
Re: CCR 100 Percent CPU
Tue Apr 01, 2014 11:58 am
They are multicore optimized. Maybe something else is causing this, please make a supout.rif file and send to support.
Chupaka
Wed Apr 09, 2014 12:17 am
you can see per-cpu profiling in Terminal:
/tool profile cpu=6
for my CCRs, 100% of one core uses 'management' process. any info from support?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
nz_monkey
Wed Apr 09, 2014 12:54 am
Huh, when did BGP become multicore optimized ?
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
dkpeall
Sun Apr 13, 2014 7:41 pm
BGP seems to max out one CPU at a time, I'm running 6.11 of this router and the maxed out core is always running the BGP process.
drbaker
Sat Apr 26, 2014 11:13 pm
I founded the same issue with scripts execution.
ofendt
Tue Apr 29, 2014 11:13 pm
I upgrade from 6.9 to 6.11 and now the RouterOS uses 100% CPU (in PROXMOX) and is unaccessible.
Same on 6.12
No Routing no Terminal no Winbox... not sure what uses the CPU...
ropeba
Tue Jul 08, 2014 9:10 pm
I have same problem, cpu core 34 is always over 90% and completely router have problem because of that.
[admin@FTTH/B GW] /tool> profile cpu=34
NAME CPU USAGE
firewall 34 91.5%
networking 34 1.5%
winbox 34 0%
management 34 0%
routing 34 0%
idle 34 6.5%
profiling 34 0%
queuing 34 0.5%
unclassified 34 0%
Chupaka
Tue Jul 08, 2014 10:41 pm
look at your firewall rules. for example, do you use 'connection-limit'?
ropeba
Tue Jul 08, 2014 11:00 pm
Hi, I don't use connection-limit. I have two drop rules and about 20-30 accept rules. Problem also persist when I disable all filter rules.
Users browsing this forum: MSN [Bot] and 85 guests
