spirry
RB951Ui-2HnD, 6.11, bootloop?
Tue Apr 08, 2014 5:53 pm
So today I upgraded my Router to 6.11, and reset the configuration, upon startup I choose to remove the default the configuration and started configure it.
What I did was to basically add a couple of VLAN's, created some bridges, disable the WLAN.
I then moved it to its intended location and it wouldn't boot up, no beep or anything, and when looked at, all links would turn on for a second and then just go off and repeat.
So I took it back, netinstalled it, and tried the same procedure again and same thing happened upon reboot.
Netinstalled it once again and this time I just removed the default configuration and rebooted and once again it just kept looping without ever coming on.
Once I downgraded the device to 6.0 its working perfectly though so the unit itself should be good.
What gives? Anyone else ran into the same issue with 6.11?
patrikg
Re: RB951Ui-2HnD, 6.11, bootloop?
Tue Apr 08, 2014 6:08 pm
Did you tried to upgrade the bootloader firmware of the routerboard also.
Not only the ROS (router operating system).
http://wiki.mikrotik.com/wiki/Manual:Bootloader_upgrade
spirry
Tue Apr 08, 2014 6:17 pm
I just did and same thing
spirry
Wed Apr 09, 2014 10:04 am
So no one got anything?
Is anyone successfully running 6.11 on 951Ui-2HnD? Firmware version?
nerdtron
Thu Apr 10, 2014 6:03 am
Exactly the same device here. I tried upgrading to 6.11, remove default configuration, then configured Same scenario as yours and the router works properly.
Tried to unplug and replug a few times and bootup is successful everytime.
Anyway, I went to 6.10 again because it's already what I use on other routers.
lessonz101
Sun Apr 20, 2014 1:28 am
Having the same issues on my crs125. It gets to starting services then reboots, the console just shows non standard characters and squares. Starting a new thread on it.
Users browsing this forum: No registered users and 215 guests
