WirelessRudy
fcs error?????
Tue Apr 15, 2014 3:10 pm
fcs error scrndump.docx
What is this? My log shows "fcs error" on link attached to an interface... what the hell does it mean and where is it coming from?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
Duduhandelman
Re: fcs error?????
Tue Apr 15, 2014 8:00 pm
Verify speed and duplex at both ends of this interface.
It mean that the crc on the layer 2 is incorrect.
I have seen this before with mismatch duplex or faulty cable.
WirelessRudy
Re: fcs error?????
Wed Apr 16, 2014 1:13 am
well, checked that. Both ends are the same setting. So I don't know. Didn't happen anymore today. Lets see what happens tonight....
Rudy R. Puister
OvrMyHed
Re: fcs error?????
Fri Aug 15, 2014 2:14 am
I am having the same issue.
FCS Error Ether 8
Replaced cable (tested and verified) power supply (also tested) and checked for duplex (100mbs router and radio) Still getting error.
Several Radios are connected to the UBNT sector. Would I need to check them as well?
Any other ideas?
texmeshtexas
Re: fcs error?????
Thu Sep 04, 2014 3:53 pm
I believe this is part of the flow contol mechanism that was added to Ethernet interfaces in RouterOS 6.12+
Not a new concept in Ethernet but new to MT.
I had this issue on one of my CCR1036 interfaces connected to a SAF backhaul. The SAF turns flow control on (no option to turn it off) and I had not turned it on in the CCR1036. Turned it on and now its happy.
I've discovered that many backhauls implement flow control on the Ethernet port, wheather they state it in the manual or not.
alishaown
Re: fcs error?????
Sun Sep 04, 2016 6:27 pm
Interface Warning : eth1 Connection fcs error on link????
please help to solve this problem
doush
Long time Member
Long time Member
Re: fcs error?????
Mon Sep 05, 2016 12:47 am
FCS arror indicates a physical problem either with the cable or the connected devices ethernet ports.
WirelessRudy
Re: fcs error?????
Mon Sep 05, 2016 1:20 am
well, might be but the MT software is either too sensitive or has bug. We use latest stable softwares and firmwares and have at several places fcs errors coming up at times. Sometimes for months nothing and than suddenly one, some or many ports on a router show fcs errors. Sometimes only 2,3 a day, sometimes several per minute and then suddenly stop to not to come back for weeks...
This is a router in a cool stable basement were nothing happens.....
Rudy R. Puister
ernandesks
Re: fcs error?????
Tue Jun 12, 2018 3:11 am
I'm having this same problem on ccr 1036 2sfp + and the problem appears on all ports is varying by day which port will display error and sometimes in a matter of minutes presenting this error the harder was that it started presenting only in ether7 and with the passing of the time present in ether1,2,3,4 is random
Jhonatanlsc
Re: fcs error?????
Wed Jan 16, 2019 4:39 am
The solution to the problem of FCS error, is because the wiring is damaged, is not adequate, etc. it happened to me the same in Rb2011 uiasrm on the switch 1 gigabit ethernet had a 10/100/1000 modem connected and both were connected with a rj45 cat 5e cable and showed me that error frequently until I changed cable and solved issue
jphconstantin
Re: fcs error?????
Wed May 01, 2019 5:06 pm
I also have this message in my log during 6 days
The connected machine is a Raspberry 3b+, I disconnected during 6 days and the message was logged. Now I am back, reconnected the RPI and no message.
The cable is long: 10 meters !
Antenna effect ?
ccr1009-7g-1c-pc
router os v 6.46.4
sindy
Re: fcs error?????
Wed May 01, 2019 5:20 pm
Antenna effect ?
I'd rather vote for a small dust particle in the connector unless you operate your setup in an environment with a high electromagnetic interference - on a power plant or substation, or next to an AM broadcasting station.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Kikomachine
Re: fcs error?????
Tue Jul 16, 2019 10:40 am
We've been experiencing the same fcs error every once in a while.
Tried power cycle reset, it works fine for a while but after a few hours or day errors come back again.
My wireless network suffers as it loss it connectivity or work intermittently.
What would be the possible cause of it?
Possible solutions?
Thanks in advance guys
sindy
Re: fcs error?????
Wed Jul 17, 2019 9:49 pm
@Kikomachine, on wireless or wired interface?
Users browsing this forum: Google [Bot], mhaluska, norg and 75 guests
