koMar
hardware for pppoe server
Thu Apr 24, 2014 5:35 pm
Hi all!
What is your reccomendation for routerboard for PPPOE Server? I am planning to have about 400 users/pppoe sessions running.. Also, this router will be the Core router. It will handle firewall traffic, NAT, scripting, MPLS, routing. All traffic that is comming from our towers (we are wisp) at end is going through this router. We have 100 mbit/s internet connection and so far 300 users.
Is it RouterBOARD 1100Hx2 enough? Or if not, will it do if i go with two RouterBOARD 1100Hx2 in load balance?
Or should i just go with cloud core router (16 cores).. although redundancy will be more expensive with this model..
Thanks!
Regards,
Marko
rextended
Re: hardware for pppoe server
Thu Apr 24, 2014 6:21 pm
RB1100AHx2
I'm Italian, not English. Sorry for my imperfect grammar.
rickfrey
Trainer
Trainer
Thu Apr 24, 2014 6:22 pm
I would use one of the Cloud Cores. Yes, the smaller ones should be able to handle that load. The 1100AH will probably handle it just fine, but for the price difference why not just use one of the CCRs that you know will handle it and will grow with you? If you have plans to upgrade your ISP, the CCR will be a better choice for you in the long run.
Launch your company forward with professional training!
http://rickfreyconsulting.com/product-c ... raining-2/
rextended
Thu Apr 24, 2014 6:27 pm
Is better one sinlge CCR with no redundancy or two RB1100AHx2 with redundancy?
koMar
Fri Apr 25, 2014 2:56 pm
Thanks all on answers!
Yes, that's my question too.. i agree it's better to buy cloud router if planning to have more users.. but two of those is expensive.. is it better like rextended said to use two of AHx2 or one cloud core?
Do you have some experience with redundancy? Does it work ok? If yes, in my opinion two AHx2 is better because you have redundancy and still 2x2 cores..
rextended
Fri Apr 25, 2014 3:02 pm
I have 2 RB1100AH (not x2) as router for 4 100Mbps link (2 for each rb) bi-directional guaranted with InteRoute.
and 4 RB1100AHx2 as Gateway (PPPoE server, firewall, NAT, etc.) each one have from 700 to 1000 users.
Each RB are cross-connected for failover.
All this hardware are still to RouterOS 6.7 and BIOS [firmware] 3.10
koMar
Fri Apr 25, 2014 3:58 pm
Thx rextended,
How did you setup pppoe redundancy?
rextended
Fri Apr 25, 2014 4:03 pm
Thx rextended,
I use EoIP between each single wlanX to multiple PPPoE server inside same Gateway.
On the Access Point are one script and change EoIP dst accordingly to what Gateway are reachable, if the default for that panel are unreachable
magnavox
Thu Nov 12, 2015 3:14 pm
Thx rextended,
@rextended
How manage load balancing to PPPoE Servers?
Best Regards...
rextended
Fri Nov 13, 2015 11:24 am
@rextended
I do not do it automatcally,
I move the EoIP "end" by "hand" on the more free server based on my statistics.
Load balancing can not be automatic.
The user must not be disconnected each time the connection must be "moved".
Also, you can not disconnect users, you can eventually only force just-powered-on users on new servers by script.
(I do not have made that script, and I not know if someone have written it)
For balancing (manually without EoIP) you can use on CPE "pppoe-out" the fields
"Service" (= /interface pppoe-server "Service Name" of PPPoE Server entry)
or
"AC Name" (Access Concentrator Name = "/system identity "name" of the PPPoE Server)
on "PPPoE Client"s
magnavox
Fri Nov 13, 2015 12:25 pm
@rextended
or
on "PPPoE Client"s
True, but this is a static assignation and need activate the Service Name on other NAS if a NAS die... ;)
Best Regards...
chechito
Fri Nov 13, 2015 4:21 pm
i think between
rb1100ahx2 at 350us
and
CCR1009-8G-1S-1Splus at 495 us
the best investment is the ccr1009, because it costs 1.5x the rb1100 but gives at least 3.0x the performance
the best money vs performance its the cheapest version of ccr1036 it cost 2.0x the ccr1009 (995us) but gives at least 4.0x the performance
rb1100ahx2 vs CCR1036-12G-4S
ccr1036 costs 3.0x the rb1100 but gives at least 12.0x the performance
magnavox
Fri Nov 13, 2015 4:42 pm
CCR sure!
Best Regards...
Users browsing this forum: Bing [Bot] and 78 guests
