Yuuki
Load Balance PCC issue? Advice needed
Thu May 01, 2014 7:07 pm
I'm trying to load-balance two WAN Lines, Try the MikroTik Wiki no luck... Tried Youtube... also no luck
My Configurations
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
add name=dhcp_pool1 ranges=192.168.3.2-192.168.3.254
add address-pool=dhcp_pool1 disabled=no interface=DMZ name=dhcp1
/port
set 0 name=serial0
add bridge=DMZ interface=LAN
add address=192.168.3.1/24 interface=LAN network=192.168.3.0
/ip firewall address-list
add address=192.168.3.0/24 list=LOCAL
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ISP2
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
interface=ISP1
add address=192.168.3.0/24 dns-server=192.168.3.1 gateway=192.168.3.1
set allow-remote-requests=yes
/ip firewall mangle
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
ISP1 new-connection-mark=ISP1_conn
ISP2 new-connection-mark=ISP2_conn
add action=mark-routing chain=output connection-mark=ISP1_conn \
new-routing-mark=to_ISP1
add action=mark-routing chain=output connection-mark=ISP2_conn \
new-routing-mark=to_ISP2
add chain=prerouting comment="Accept LOCAL Addr" dst-address-list=LOCAL
add chain=prerouting dst-address=192.168.3.0/24 in-interface=LAN
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=LAN new-connection-mark=ISP1_conn per-connection-classifier=\
src-address:2/0
in-interface=LAN new-connection-mark=ISP2_conn per-connection-classifier=\
src-address:2/1
add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
in-interface=LAN new-routing-mark=to_ISP1
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
in-interface=LAN new-routing-mark=to_ISP2
add action=masquerade chain=srcnat out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2
add check-gateway=ping distance=1 gateway=ISP1 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=ISP2 routing-mark=to_ISP2
add check-gateway=ping distance=2 gateway=ISP2
I'm currently just testing the two WAN lines with Private IP, But i'm unable to NAT out of the network. Please Advice
Ibersystems
Re: Load Balance PCC issue? Advice needed
Thu May 01, 2014 11:29 pm
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
jarda
Thu May 01, 2014 11:45 pm
Oh. This is inspirative. I use netwatch for this purpose. But this could be faster. How often is checked the GW when ping check is in place? And of course, it disallows routing to fictive IPs if they are not fictive... What happens if redundant host checking is used and one host is down and other up? Does the recursive routing have any influence on perfirmance?
Ibersystems
Fri May 02, 2014 1:11 am
This works in all situations.
Martín
Yuuki
Fri May 02, 2014 4:03 am
This is fairly interesting... playing with the route distance.... I'll try it if PCC method really really doesn't work...
I'm trying to do a Load-Balance using this two WAN lines, or PCC isn't design for such usage? But just now I'm unable to surf the net. BUT if i enable the option DHCP client "add default route", it would work, I can surf the Net, But is PCC supposed to be configured this way?
how come the Mikrotik Wiki example can't even work?.... I'm confused...
Oh gosh.. that's just more questions to my question... :P
Ibersystems
Fri May 02, 2014 8:40 am
It works. Your router always need IP and routes configured...
Martín
Yuuki
Sat May 03, 2014 7:39 am
You mean the Mikrotik Wiki Example Works? Why would the DHCP client default route need to be enabled?
when i have this?
/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_ISP1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_ISP2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 distance=2 check-gateway=ping
I'm utter lost right now...
Ibersystems
Sat May 03, 2014 10:06 am
This route is for the router itself.
You dont mark the output chain... Then the router needs to have 2 default routes. One for isp1 and one for isp2.
Martín
pongko
Tue May 06, 2014 3:49 am
I always do like this ..
1. Create routing table for each ISP with its own gateway respectively.
2. Create routing rule for each ISP with its routing-mark respectively.
its work flawlessly..
Sorry for my English, I'm not English.. :)
Users browsing this forum: No registered users and 58 guests
