mankomal
Netinstall boot failure 10013
Mon May 05, 2014 11:41 am
Hi
I am using Windows 7 and facing problem with Netsinstall for last 2 months now, I am getting following error :
bind bootp failed: An attempt was made to access a socket in a way
forbidden by its access permissions.
(10013)
(See pic)
Please help me resolve this
regards
patrikg
Re: Netinstall boot failure 10013
Tue May 06, 2014 11:46 am
As Normis say's at this post:
http://forum.mikrotik.com/viewtopic.php ... or#p423320
Make sure your Windows PC has Firewall and Antivirus turned off, and that you run Netinstall "As Administrator".
And here how easy to do it 8 ways.
http://www.sevenforums.com/tutorials/11 ... rator.html
allstarcomps
Sat Jul 08, 2017 10:46 pm
**** A Fix*****
After allowing the ports though win 10 firewall, static IP and so forth. Netinstall continued to give me the 10013 error. Looking up TFTP port is 69. I Opened a command prompt as an administration and ran netstat -a -b. Found out JAVA.exe was using port 69. Opened task manager and killed everything related to java. Ran netstat -a -b, no entries for port 69. Ran netinstall and it worked like a charm.
For those skimming for a fix:
Open task manager
kill anything related to java
run netinstall
Users browsing this forum: Bambie, maungmaungmyatsan and 65 guests
