We have a serious issue with PPPoE client in RouterOS.
At random intervals, the PPPoE client stops passing traffic.
Seen from the PPPoE server side, it is still connected, but no data is passing.
After a few hours it reconnects, then everything is back to normal.
If disconnected from the server side manually, it reconnects, and back to normal again.
I have created a script to check an external IP address with ping, and disable-enable the PPPoE client if necessary.
It seems to work in most cases, however not always. (In this cases I cannot even see a log entry about disabling and enabling the interface.)
We have this issue with two RB750GLs, tried with RouterOS v6.10, v6.12 and v6.13rc12. All of these have the problem.
Has anybody seen something similar?
