more liberal? You mean it can wave flags and pull down monuments?What's new in 2.9.24:
*) made roaming handling in AP more liberal to support different
interpretations of 802.11 (for Siemens WL2);
think this is it, and maybe some minor changes ment not for mentioning hereWhere are the notifications about WinBox???
Mike
*) added option to WinBox to not automatically open previous session windows
works only with v2.9.24;
Yes, these change logs make my BP rise sometimes. Should be:think this is it, and maybe some minor changes ment not for mentioning hereWhere are the notifications about WinBox???
Mike
Code: Select all*) added option to WinBox to not automatically open previous session windows works only with v2.9.24;
If you're using a demo license, you cannot upgrade, you will need to install from scratch (or buy a license)Hi,
I have just downloaded and installed the 2.9.24 vers. and after install and reboot, MK just says that the demo license has expired, without working on single second
It's this a known bug ? if so, any work around?
bgp setup w/ routing-test won't work without redistribute connected, in version 2.8.28 w/ regular routing, filtering won't work correctlywhatd do you want fixed?still no bgp fixes, damn :(
Hellowhatd do you want fixed?still no bgp fixes, damn
routing bgp instance> print
Flags: X - disabled
0 name="default" as=1286 router-id=10.17.119.1 redistribute-static=yes
redistribute-connected=no redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter="" client-to-client-reflection=no
Destination: 10.94.141.0/24
BGP AS Path: 3757,4790,2379,913,410,3180,3170,2801,2804,38,941,199,3329,2315,1,2615,5023,45,8580,65141
Just to let you know that this issue still seems to be there in the CF image. Copied the image to CF then installed on a WRAP and got the license expired message. Install 2.9.23 then upgrade to 2.9.24 works fine.no, janisk, the problem was not with upgrade, but with clean install. please re-download the CD installation ISO, we have fixed the issue. the new ISO will be online in 3 minutes.
Yeah, you are not the only one who have problem with crashing winbox efter upgrading to 2.9.24.Ahh so is this Install issue a wide spread problem? I've got 3 routers i cant winbox too because it crash's but atleast they work
