mhugo
Issues with ipv6 smaller than /64
Sat May 17, 2014 8:51 am
Were finally putting in ipv6, but we have issues with our upstreams since they provide smaller networks for the links than /64.
In mikrotik it says unreachable and we cant ping them. If we use the link local fe80 then it works and also the links carry ipv4 without any problem. Its a CCR1036-12G-4S-EM and all upstreams are on SFP ports.
Example is Cogent 2001:978:2:a4::2:0/112.
/Mikael
IPANetEngineer
Trainer
Trainer
Re: Issues with ipv6 smaller than /64
Sat May 17, 2014 9:38 pm
Can you post your config or supout.rif?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
janisk
Mon May 19, 2014 1:09 pm
we have not seen problems with different ipv6 addresses unless you are using /127 that was initially barred from use as did not provide anything useful, only wasted addresses (not a huge issue using ipv6 address space) and opened some attack vectors for attackers (that is still huge problem when /127 i sin use)
Also, if you want to advertise ipv6 addresses, you will be required to have /64 as that is set in RFC as minimal for end user hosts.
I myself am using /128 extensively without any issues.
mhugo
Sat May 24, 2014 8:49 pm
Reboot solved it. IPV6 does not seem 100% stable.
Users browsing this forum: dhiaahmed, gordonr, hazar, jprietove, Majestic-12 [Bot], SinTeZ and 82 guests
