kozmonov
Block Broadcast and Multicast, Consequences of doing so?
Sun May 18, 2014 8:48 pm
I am considering blocking Broadcast and Multicast traffic through my network. Im just not sure what the ramifications are of doing so...
What services would I be blocking if I drop all broadcast and multicast packets?
(Discovery, NTP, OSPF, ... ?)
IPANetEngineer
Trainer
Trainer
Re: Block Broadcast and Multicast, Consequences of doing so?
Sun May 18, 2014 10:12 pm
You would effectively shut down your network....IPv4 requires Layer2 multicast and broadcast for ARP to work along with a number of other protocols.
Limiting the rate of broadcast/multicast traffic would be a better solution...you accomplish this by turning on the firewall for bridge traffic in bridge settings and writing rules to limit broadcast/multicast appropriately.
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
kozmonov
Sun May 18, 2014 10:27 pm
I see. Is there any way to distinguish the traffic, arp or otherwise? If I was using a static apt table, would blocking multicast/broadcast prevent clients from communicating with the gateway? Would doing so also isolate clients from each other on this network?
Thanks for the response.
IPANetEngineer
Trainer
Trainer
Sun May 18, 2014 10:30 pm
Is your goal to isolate clients at Layer 2?
kozmonov
Sun May 18, 2014 10:43 pm
Yes, definitely. I'm also not sure what an acceptable level of broadcast/multicast traffic would be on a medium sized bridged network.
IPANetEngineer
Trainer
Trainer
Sun May 18, 2014 11:11 pm
Wireless, Wired or Both?
IPANetEngineer
Trainer
Trainer
kozmonov
Sun May 18, 2014 11:27 pm
It's both. At the head end, I have a tough switch powering various access points, though. Can't do port isolation without implementing VLANs first on those devices..
So while clients can't speak with their next door neighbors (attached to the same rb2011 or cloud router switch), they could communicate with clients connected to other access points.
IPANetEngineer
Trainer
Trainer
Sun May 18, 2014 11:39 pm
For wireless - check the following setting on the WLAN
ros code
default-forwarding=no
For wired
it varies depending on the switch, but Private VLANs/Port Isolation are the way to go.
Users browsing this forum: Akuras, jamrobe, skraw, sonnyboy and 173 guests
