obadaabdullah
am i under attack??
Mon May 19, 2014 1:20 am
what is this ???
am i under attack??
it's from my log file:
"may/19 01:15:10 system,error,critical login failure for user root from 116.10.191.227 via ssh "
jarda
Re: am i under attack??
Mon May 19, 2014 4:13 am
Yes. Just logging tryouts. How many per minute are they?
obadaabdullah
Mon May 19, 2014 10:21 am
what is logging tryouts??
in log file i get this msg a lot but not all times,
when i write this post there was a lot msgs (maybe 100)
and i got this on google:
We're sorry...
... but your computer or network may be sending automated queries. To protect our users, we can't process your request right now.
See Google Help for more information.
Caci99
Mon May 19, 2014 2:26 pm
As @jarda eplained, they are just attempts to log in on to your router. I shouldn't be very concerned as long as you change the default user and the password. But if you want, you can add this to your firewall:
http://wiki.mikrotik.com/wiki/Bruteforc ... prevention
-Toni-
Don't crash the ambulance, whatever you do
derr12
Thu May 22, 2014 9:29 pm
I eliminate a lot of these by simply turning off the access methods im not going to use.
In IP - > services. If you dont use ssh and are winbox only like me you can turn off everything except winbox. easy-peazy.
Users browsing this forum: Baidu [Spider], sindy, w0lt, Znevna and 106 guests
