MUM Europe 2020
mag
OpenVPN
Sat May 20, 2006 6:56 pm
Maybe it would be worth to consider implementing OpenVPN in 2.1 or 2.x.
hennessy
Mon Oct 23, 2006 11:16 am
I would definitely vote for that
normis
Mon Oct 23, 2006 11:26 am
it's on the wish list, maybe in v3 it will be made
changeip
Re: OpenVPN
Mon Oct 23, 2006 6:54 pm
I havent looked into OpenVPN much, but if it's OPEN why can't it talk with the standard VPN protocols as well? : )
Sam
cmit
Mon Oct 23, 2006 7:23 pm
Different kind of beast - OpenVPN is basically a SSL-based VPN solution.
But a good one, for several scenarios. One of the sexy things is that you can get it through almost every firewall - you just need to open a single port...
Best regards,
Christian Meis
npero
Tue Oct 24, 2006 8:15 am
One more vote for OpenVPN. Also work throughout proxy try some other VPN solution but this work almost on any place only need one port open to work.
Best regards.
BrianHiggins
Long time Member
Long time Member
Fri Oct 27, 2006 5:28 am
you have my vote as well, many cellular carriers will not allow VPN traffic through your data service without paying additional fees, a SSL VPN would be nice.
J0ke
Tue Nov 07, 2006 3:25 pm
must have!
normis
Tue Nov 07, 2006 3:26 pm
already in development
wsgtrsys
Mon Jan 29, 2007 3:42 pm
Hope add in 3.0
normis
Mon Jan 29, 2007 3:44 pm
YES! see above post
NoXy
Thu Feb 01, 2007 11:23 pm
Yes, OpenVPN support would be nice?
Maybe v3beta6 includes that????? 8)
janisk
Fri Feb 02, 2007 10:31 am
as normis said it is in development but there will be no other deadline other than stable 3.0 hope it gets faster, but it only depends on MT programmers :) when they manage to get code stable enough.
so patience.. :oops:
quican
openvpn
Wed Feb 14, 2007 2:58 pm
Any have a "how to" guide about Openvpn and mikrotik conections?
i need connect my computer to a remote mikrotik router.
Cya! and thanks.
normis
Wed Feb 14, 2007 3:01 pm
if you read this thread carefully, you will see that openvpn is not supported by RouterOS right now.
quican
Wed Feb 14, 2007 4:04 pm
oh! tank you and sorry.. im from argentina and my inglish is not good. thanks a lot for answer and sorry for disturb the people.
burkon
Re: OpenVPN
Thu May 31, 2007 12:48 pm
Is there any update on this available?
Thank you
Ekkehard
mrz
Re: OpenVPN
Thu May 31, 2007 12:57 pm
It looks like in Ros beta8 supports OpenVPN
you can access it in console:
/interface ovpn-server
/interface ovpn-client
Alex
Re: OpenVPN
Thu May 31, 2007 1:27 pm
with what packages?
mrz
Re: OpenVPN
Thu May 31, 2007 1:40 pm
with ppp package
rabbtux
Re: OpenVPN, ... openVPN ROCKS!
Fri Jun 01, 2007 9:40 am
I've been using this many places for several years. Never did the pptp thing until I migrated many APs to Mikrotik. Ran into all kinds of problems, in that pptp does not support multiple connections from behind a single nat firewall to one destination! With openVPN you can run through all kinds of nat firewalls and only use one port on the server.
Never tried the Version 3 beta. how stable is the hotspot functions?
My 7 MT systems vote for openVPN to show up in V2.9! :)
janisk
Fri Jun 01, 2007 10:29 am
for PPTP worh through firewall use PPTP helper, that way you can have as many as you want pptp tunnels through nat
normis
Re: OpenVPN
Fri Jun 01, 2007 4:42 pm
to translate the previous post - to make PPTP work through NAT, you have to enable the GRE NAT HELPER. See manual (eg. read how to configure it, and then it will work fine)
rabbtux
Sat Jun 02, 2007 4:32 am
unfortunately my border firewall/nat is not Mikrotik, rather Gentoo. The real point is that with openVPN I never need firewall helpers/modification for VPN clients.
normis
Mon Jun 04, 2007 2:47 pm
too bad then. in this case you can also use L2TP which is similar to PPTP but does not require a helper
rabbtux
Re: OpenVPN
Tue Jun 05, 2007 2:13 am
Thanks for suggestion. Are we talking about putting pptp inside L2TP tunnel, or just L2TP by itself?
Is L2PT hard to setup on my Ubuntu virtual server (on the net), as I assume it's not too difficult with Mikrotik :-)
normis
Re: OpenVPN
Tue Jun 05, 2007 8:25 am
In mikrotik it's a piece of cake. yes, I was talking about a standalone L2TP tunnel.
bcnl
Re: OpenVPN
Thu Jun 07, 2007 3:08 am
Can you use winbox to setup the parameters for the OpenVPN server? Is there any documentation for this yet?
PS: Thank you VERY VERY much, I bought a routerboard a while ago but did not deploy it yet as I was waiting for the OpenVPN support to be added. Now all we need is hardware support for the hardware encyption cards :D
janisk
Re: OpenVPN
Thu Jun 07, 2007 1:06 pm
sorry currently only console is available
bcnl
Re: OpenVPN
Thu Jun 07, 2007 6:30 pm
Where would I find information on setting it up? I assume I need to put my root CA on the router as well as generate a CA for the router, would that be under certificates? After that's done I'm still not sure on the best way to actually set it up, it's not like I can just edit the openvpn.conf file like I can on a Unix system.
Thanks in advance for any help or advice.
changeip
Re: OpenVPN
Thu Jun 07, 2007 6:42 pm
winbox does have a gui for it under PPP.
Sam
bcnl
Re: OpenVPN
Fri Jun 08, 2007 2:20 am
Cool,
Well I enabled it under PPP , created a open-vpn server interface, uploaded my root CA, and uploaded a signed cert for the rb500 but I cannot seem to connect to it from a workstation... I get no response. Sorry for all the questions, but I'm quite new to the routerboard and do not know where to look to diagnose this problem.
Any help would be appreciated.
normis
Re: OpenVPN
Fri Jun 08, 2007 8:54 am
what client are you using on a workstation? surely you are aware that you need an openvpn client, which is not easy to configure.
YourSelf
Re: OpenVPN
Fri Jun 08, 2007 11:54 am
I have tested it for a few moments, I also had a problems connecting in and out, but then I noticed that Mikrotik uses OpenVPN via TCP not via UDP which is normally default. When I changed to TCP on the other side, it partialy worked - I connected but then it got stuck somewhere after that. I could look at it again, but I had a little time. If I have not missed anything, there is currently no way how to change to UDP in mikrotik OpenVPN. I have used winbox, it could still be possible in command line, but I have not tested that.
Also I have noticed that in "ethernet" mode, the OpenVPN interface does not support bridging, bonding and possibly other ethernet-like interface features.
bcnl
Re: OpenVPN
Fri Jun 08, 2007 6:41 pm
Normis,
I'm using the latest 2.0.9 client on windows, however in my setup I have unix/mac/pocket pc/windows clients and servers so I'm moderately experienced with configuration of the software. Currently for testing I'm using Mathias Sundman's excellent OpenVPN Gui as it's status window is a lot better than a dos box IMO.
I've changed my protocol to TCP as suggested by another board member and can now initialize the connection, however I'm still having some issues but at least I'm on the right track. Is there a chance that UDP support will be added before the beta is over? Tunneling TCP inside of TCP is a bit of a waste, and the UDP support of OpenVPN is one of the reasons I chose to go with it in the beginning.
bcnl
Re: OpenVPN
Thu Jun 28, 2007 6:27 pm
Will there be any inprovements made to the OpenVPN code in the next beta? Is there anything I can do to help with the development or testing?
wsgtrsys
Re: OpenVPN
Fri Sep 07, 2007 2:54 pm
wish add UDP support!!
netrat
Re: OpenVPN
Tue Sep 11, 2007 7:31 am
Yes I think this should be at the top of the list. Why are TCP tunnels even used? This is a newer feature in OpenVPN and they recommend that you don't use it, due to connections stalling out and the overhead.
OpenVPN is designed to operate optimally over UDP, but TCP capability is provided for situations where UDP cannot be used. In comparison with UDP, TCP will usually be somewhat less efficient and less robust when used over unreliable or congested networks.
rabbtux
Re: OpenVPN
Tue Sep 11, 2007 9:54 am
me two, or three. This is the killer app for me, as I could replace several embedded linux boxes with mikrotik if only it had 'normal' openvpn support. (UDP and certificate support)
Users browsing this forum: Bing [Bot], done411, foraster, IneverexistCZ, Kampfwurst, klema, MrdotApple and 148 guests
