w0lt
RB2011UAS-RM and Mangle
Tue May 27, 2014 7:34 pm
I have a RB2011UAS-RM (v6.13 - 3.14) and have set the Ethernet ports to the following configuration:
ether1 - Master Port
ether2-5 - Slaved to ether1
ether6 - Master Port
ether7-10 - Slaved to ether6
sfp1 - slaved to ether1
bridge - Loopback
bridge port - ether1
bridge port - ether6# may/27/2014 11:28:18 by RouterOS 6.13
This configuration seems to work just fine as a switch, which is what I was designing it for. However, I can't seem to get a mangle rule to detect any selected IP or Port. The only thing I can get it to do is detect "all" activity coming through the port, in this case..ether1. I want to mark traffic coming from a selected IP address and port but can't seem to manage it. Is this a bug, or have I got this configured wrong? Review the Packet Flow diagram, it should be possible.
# software id = YY4W-FNJ5
set [ find default-name=ether2 ] master-port=ether1
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] master-port=ether1
set [ find default-name=ether5 ] master-port=ether1
set [ find default-name=ether7 ] master-port=ether6
set [ find default-name=ether8 ] master-port=ether6
set [ find default-name=ether9 ] master-port=ether6
set [ find default-name=ether10 ] master-port=ether6
set [ find default-name=sfp1 ] auto-negotiation=no master-port=ether1
add l2mtu=1598 name=Loopback
add bridge=Loopback interface=ether6
add bridge=Loopback interface=ether1
/interface bridge settings
set use-ip-firewall=yes
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
rextended
Re: RB2011UAS-RM and Mangle
Tue May 27, 2014 8:20 pm
"/firewall export compact"
I'm Italian, not English. Sorry for my imperfect grammar.
w0lt
Tue May 27, 2014 9:47 pm
I have a VERY simple firewall..Just troubleshooting Mangle
may/27/2014 13:46:24 by RouterOS 6.13
/ip firewall mangle
add action=mark-connection chain=input new-connection-mark=SBS_3 protocol=tcp \
src-address=172.16.10.56 src-port=10001
MTCNA - 2011
rextended
Tue May 27, 2014 9:51 pm
I ask the firewall because i see the cause of your problem now:
if you want see bridge traffic, you must use forward chain, not input or output chain.
This two chain are reserved only for traffic directed or generated to router.
Users browsing this forum: MSN [Bot] and 15 guests
