LeoCombes
Feature request: DHCP accounting through Radius
Wed Jun 04, 2014 8:14 pm
Would be nice if the routerOS dhcp-server allow logging with radius accounting.
We use dhcp-server from mikrotik and we need have a log of each IP we offer to each client and when, through radius.
rextended
Re: Feature request: DHCP accounting through Radius
Wed Jun 04, 2014 9:07 pm
But... ALREADY you can do that...
I'm Italian, not English. Sorry for my imperfect grammar.
LeoCombes
Thu Jun 05, 2014 12:49 am
Really?
In which version?
Sorry if already can do this :oops:
rextended
Thu Jun 05, 2014 12:50 am
Really?
In which version?
I see that option (but i do not use this) on RouterOS 6.7+
LeoCombes
Thu Jun 05, 2014 1:02 am
I have a routerboards with 6.1v and 6.5v and not see that option.
Mikrotik manual http://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server does not say anything about it, maybe it is not updated?
rextended
Thu Jun 05, 2014 1:04 am
When evaluate something, use near last version...
but I can see on the wiki the "use-radius" option.... you not?
It is also possible to hand out leases for DHCP clients using the RADIUS server, here are listed the parameters for used in RADIUS server.
About how it work, I do not know, I never try.
LeoCombes
Thu Jun 05, 2014 1:37 am
But that option doesn't make accounting, it just make authorization.
We need accounting.
Let me to give you an example:
1- device ask for IP to routerboard
2- routerboard ask for IP a radius server (autorization)
3- freeradius replies to routerboard with an IP address for the client
4- routerboard offer an IP to device
...this is what does the routerboard currently.
Even though, if it also does the accounting
5- the router reports to server that provided the IP xxx to customer Y (accounting)
This allows to use a DHCP server and pool of IPs in the routerboard and only use the radius server for accounting of IPs offered:
2- routerboard offer a IP from own pool to a device
3- the routerboard reports to server that provided the IP xxx to customer Y (accounting)
Currently can not keep track of the IPs that the routerboard delivers to customers.
rextended
Thu Jun 05, 2014 1:53 am
But this three passages can be done by user-manager...
I must verify that, but about FreeRADIUS, i do not use it.
I can try only on RouterOS user-manager.
LeoCombes
Thu Jun 05, 2014 2:01 am
But... from user-manager manual:
Note, first local router database is consulted, then User Manager database. User will be unable to obtain DHCP lease, if DHCP router and User Manager server will not contain any information about user's data.
We not have any information from user data, is just a DHCP dynamic server.
rextended
Thu Jun 05, 2014 2:04 am
But you want ANYONE connect, or only authenticated users?
LeoCombes
Thu Jun 05, 2014 2:18 am
Anyone.
rextended
Thu Jun 05, 2014 2:25 am
Anyone.
>>>the dhcp-server allow logging with radius accounting
But accounting from one not existend account?
One account to be acconuted must be create first...
I think what you need is HotSpot to track on radius the IP offered...
what do you mean?
description:
anyone connect to dhcp-server must be converted to radius user and be logged on radius for that user the ip offered to client and when
Just checked and on future 6.14 version are added this:
*) dhcp server - added option use-framed-as-classless and added support for DHCP-Classless-Static-Route RADIUS attribute;
LeoCombes
Thu Jun 05, 2014 3:40 am
Sorry, it is perhaps difficult to understand me because I'm not good with english.
No. Is only account, not auth. Can be done, because are two different things:
Authentication and authorization allow or deny services.
Account keeps track of resources used.
...and can work together or independently.
For example:
PPPoE user dials but is not registered. His login fail because his account is not registered (auth), however his attempt is logged (account).
In the same way you can keep a log or "accounting" of things that are not registered.
Registration is not required for accounting.
Now I remember, this was already asked. Inclusive I voted for this! :lol:
http://forum.mikrotik.com/viewtopic.php?f=1&t=76840
The only difference is add the option of accounting also in the case that the allocation of IP is from a pool of the same routerboard (instead of assigning an IP from a remote radius server).
cchance
Wed Feb 04, 2015 1:31 pm
Use radius works but no accounting is sent for dhcp clients.
MIKROTIK PLEASE CONFIRM THIS IS GETTING ADDED\FIXED IN 6 OR 7!!!!!!?!???!?
awacenter
Mon Apr 27, 2015 11:26 am
+1 to implementation of DHCP accounting requests
SiB
Forum Veteran
Forum Veteran
Tue May 05, 2015 4:27 am
+ 1
nz_monkey
Tue May 05, 2015 12:12 pm
+1
I am amazed this is NOT already there.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
LeoCombes
Tue Aug 09, 2016 12:18 am
Hi!
Any news about support of radius accounting from DHCP?
Kadafi
Thu Aug 18, 2016 10:38 am
+1 for accounting
milhorini
Fri Oct 14, 2016 10:49 pm
dhcp with accounting - please...
LeoCombes
Thu Jan 26, 2017 2:37 pm
BrianHiggins
Long time Member
Long time Member
Tue Feb 21, 2017 12:16 am
also add support for MT-Rate-Limit attribute when using DHCP+RADIUS as already promised (Ticket#2016110222000039)
-Brian
http://www.aditumims.com
Complete web based ISP in-a-box solution, designed specifically for Multi-Tenant properties, works great for WISPs too.
nz_monkey
Tue Feb 21, 2017 9:03 am
This already exists! Use the Mikrotik-Rate-Limit VSA
BrianHiggins
Long time Member
Long time Member
Mon Feb 27, 2017 9:14 pm
sorry, it's in the ticket I referenced, and wasn't entirely clear in this post. what I meant was full support, which means also setting parent queue property.
Below is the request from the referenced ticket which explains in more detail.
> I have a requirement where I must be able to set the parent
> queue on the dynamic queues created when authenticating a DHCP user via RADIUS and assigning
> the MT-Rate-Limit attribute. The queue is being created properly and works, but
> I am unable to figure out a way to assign the parent queue. The result
> is when oversubscribing the connection, the queues do not properly
> function since they do not have any parent defining the total amount of bandwidth available to the users.
> I would imagine that an optional setting added to the DHCP Server or
> the Network would be the appropriate place to add the parent queue
> value just like we have on the PPP profile.
> Any way that works is acceptable, however assigning the parent queue
> via RADIUS in such a way that also applies to PPP connections without
> needing to set it via the profile would be even better (but faster implementation is even more important).
-Brian
LeoCombes
Wed Feb 07, 2018 8:52 pm
Seems that implemented on 4.41!
Now to test!
Users browsing this forum: Drageir, enzomarioaiello, Google [Bot], jhonwary, Mikelov, sindy, svmk, visupport, ztx and 65 guests
