nmaton
OPENSSL 5 june bugs
Thu Jun 05, 2014 8:44 pm
Can anyone inform us if mikrotik is vulnerable to the following openssl bugs?
https://www.openssl.org/news/secadv_20140605.txt
Nicolas Maton
nicolasmaton@gmail.com
CCNA/ CCDA
MTCNA / MTCTCE
Available for Mikrotik Consulting
janisk
Re: OPENSSL 5 june bugs
Fri Jun 06, 2014 10:38 am
if you are worried about this please upgrade to RouterOS 6.14 when released.
honzam
Fri Jun 06, 2014 11:02 am
OpenSSL bug - SSL/TLS MITM (CVE-2014–0224) - type: "Man-in-the-middle"
http://ccsinjection.lepidum.co.jp/blog/ ... index.html
LAN, FTTx, Wireless. ISP operator
robertpenz
Fri Jun 06, 2014 5:35 pm
Which services / protocols on the RouterOS are vulnerable?
janisk
Tue Jun 10, 2014 12:48 pm
just use 6.14
robertpenz
Tue Jun 10, 2014 2:20 pm
With my routers running 6.x thats easy. But we've many 5.x still and a upgrade to 6.14 is not that fast done. So I would like to know which services/protocols are affected. If I don't use them I don't need to upgrade. Or will there be a 5.x security release.
janisk
Tue Jun 10, 2014 2:45 pm
v5.x will not receive security updates.
6.14 has this security update.
lavv17
Tue Jun 10, 2014 2:51 pm
I think it's only https (www-ssl) which is affected. But I don't know for sure. Use good firewall settings and you would be fine.
robertpenz
Tue Jun 10, 2014 2:52 pm
ok only 6.x gets an security update. so switch services are vulnerable? I need this to compare the the security impact against the time and money the update from 5.x costs.
normis
Tue Jun 10, 2014 2:54 pm
You should evaluate if there are any actual risks from the described vulnerability. "Could be" doesn't mean anyone has, or ever will create an exploit. See how far are you willing to go to protect against the tiniest possibility. Upgrade doesn't seem so expensive if you think this is important.
robertpenz
Tue Jun 10, 2014 2:59 pm
What I want to know is, if only the administration (HTTPS, Winbox) is vulnerable, which would be not big problem as we're using dedicated management networks, or production service also external user can reach.
normis
Tue Jun 10, 2014 3:16 pm
These vulnerabilities have nothing to do with Winbox or SSH, your router cannot be hacked with this.
Currently I can't imagine any feature in RouterOS that could be affected with the issues in the first post.
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Bing [Bot], kinetic55, Semrush [Bot] and 63 guests
