[hspot@AMBIENTE_TESTE] > /export compact
# jan/01/1970 21:13:46 by RouterOS 6.1
# software id = IJEL-ZDRG
add l2mtu=2290 name=ADM protocol-mode=rstp
add l2mtu=1598 name=HSPOT-1
set 0 mac-address=4C:5E:0C:35:65:F3
set 1 mac-address=4C:5E:0C:35:65:F4
set 2 mac-address=4C:5E:0C:35:65:F5
set 3 mac-address=4C:5E:0C:35:65:F6
set 4 mac-address=4C:5E:0C:35:65:F7
set 5 mac-address=4C:5E:0C:35:65:F8
set 6 mac-address=4C:5E:0C:35:65:F9
set 7 mac-address=4C:5E:0C:35:65:FA
set 8 mac-address=4C:5E:0C:35:65:FB
set 9 mac-address=4C:5E:0C:35:65:FC
set 10 mac-address=4C:5E:0C:35:65:F2
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 mrru=1600 name=CTBC password=10udi032 user=
hugo.jammal@r7.com
/interface wireless
set 0 band=2ghz-b/g/n disabled=no l2mtu=2290 mode=ap-bridge ssid="Apartamento 702"
set [ find default=yes ] authentication-types=wpa-psk eap-methods=passthrough mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=espinosa191
/ip hotspot profile
add dns-name=login.internet hotspot-address=20.0.0.1 html-directory=htmlv4 login-by=http-chap name=hsprof1
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
add idle-timeout=10m keepalive-timeout=2m mac-cookie-timeout=3d name="PADRAO HSPOT" on-login=":local \"userActive\" \$user; \r\
\n:local \"mac\" [/ip hotspot active get [find user=\$\"userActive\"] mac-address]; \r\
\n:local \"ip\" [/ip hotspot active get [find user=\$\"userActive\"] address]; \r\
\n:log info \"{ 'User': '\$\"user\"', 'IP': '\$\"ip\"', 'MAC': '\$\"mac\"', 'Action': 'Login' }\"; " on-logout=":local \"userActive\" \$user;\r\
\n:local \"id\" [/ip hotspot user find name=\$\"user\"]; \r\
\n:local \"uptime\" [/ip hotspot user get [find name=\$\"user\"] uptime]; \r\
\n:local \"limit_uptime\" [/ip hotspot user get [find name=\$\"user\"] limit-uptime]; \r\
\n:local \"idInUse\" [/ip hotspot active find user=\$\"userActive\"]; \r\
\n:log info \"{ 'User': '\$\"user\"', 'UpTime': '\$\"uptime\"', 'LimitUpTime': '\$\"limit_uptime\"', 'Action': 'Logout', 'Id': '\$\"id\"', 'IdInUse': '\$\"idInUse\"' }\
\"; " rate-limit=512k/2048k shared-users=4 transparent-proxy=yes
add idle-timeout=20m keepalive-timeout=2m mac-cookie-timeout=3d name=REUNIAO on-login=":local \"userActive\" \$user; \r\
\"; " rate-limit=1024k/8192k shared-users=50 transparent-proxy=yes
add name=hs-pool-11 ranges=20.0.0.40-20.0.0.254
add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.139
add address-pool=hs-pool-11 disabled=no interface=HSPOT-1 lease-time=1h name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=ADM lease-time=1d5h name=dhcp2
/ip hotspot
add address-pool=hs-pool-11 disabled=no interface=HSPOT-1 name=hotspot1 profile=hsprof1
/port
set 0 name=serial0
/interface pptp-client
add allow=pap,chap connect-to=186.222.3.143 disabled=no max-mru=1460 max-mtu=1460 name=pptp-out1 password=hspot@hsystem profile=default user=YZRL-TSXC
/queue simple
add comment="Micro 1" max-limit=512k/2048k name="Micro 1" target=20.0.0.22/32
/system logging action
set 0 memory-lines=1000
set 1 disk-lines-per-file=1000
add name=eventHSPOT remote=192.168.1.2 remote-port=513 target=remote
add name=eventLOG remote=192.168.1.2 target=remote
/certificate scep client
add server=0.0.0.0
add bridge=HSPOT-1 interface=ether2
add bridge=HSPOT-1 interface=ether3
add bridge=HSPOT-1 interface=ether4
add bridge=ADM interface=ether6
add bridge=ADM interface=ether7
add bridge=ADM interface=ether8
add bridge=ADM interface=ether9
add bridge=ADM interface=ether10
add bridge=ADM interface=ether5
add bridge=ADM interface=wlan1
add address=20.0.0.1/16 comment="Interface HSPOT-1" interface=HSPOT-1 network=20.0.0.0
add address=192.168.1.1/24 comment="Rede ADM" interface=ADM network=192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.1.2 comment="PC HSPOT RECEPCAO." mac-address=00:22:FB:C7:AA:DA
add address=20.0.0.22 comment="Micro 1" mac-address=00:00:00:00:00:01
add address=20.0.0.0/16 comment="Interface HSPOT-1" gateway=20.0.0.1
add address=192.168.1.0/24 gateway=192.168.1.1
set servers=8.8.8.8,8.8.4.4
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat comment="Compartilha Link HSPOT-1" src-address=20.0.0.0/16 to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="Compartilha Link ADM" src-address=192.168.1.0/24 to-addresses=0.0.0.0
/ip hotspot ip-binding
add address=20.0.0.22 comment="Micro 1" mac-address=00:00:00:00:00:01 type=bypassed
/ip hotspot user
add name=admin password=hsystem@s
/ip hotspot walled-garden
add dst-host=*hsystem.com.br*
add dst-host=*hspot.com.br*
add comment="place hotspot rules here" disabled=yes
/ip hotspot walled-garden ip
add action=accept disabled=no dst-port=3050 protocol=tcp
add action=accept disabled=no dst-port=1561 protocol=tcp
/ip ipsec peer
add
add distance=1 dst-address=11.22.33.0/24 gateway=3.1.1.1
add distance=1 dst-address=20.0.0.5/32 gateway=20.0.0.1 scope=10
add distance=1 dst-address=192.168.1.2/32 gateway=192.168.1.1
/lcd
set backlight-timeout=never current-interface=ether1
/lcd interface
set 0 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
set 4 disabled=yes
set 5 disabled=yes
set 6 disabled=yes
set 7 disabled=yes
set 8 disabled=yes
set 9 disabled=yes
/system clock
set time-zone-name=America/Sao_Paulo
/system identity
set name=AMBIENTE_TESTE
/system logging
add action=eventLOG prefix=<<<usuario>>> topics=hotspot
add action=eventLOG prefix=<<<firewall>>> topics=firewall
add action=eventHSPOT prefix=jsonHSPOT topics=script
/system ntp client
set enabled=yes mode=unicast primary-ntp=159.148.60.2 secondary-ntp=200.20.186.75
/system scheduler
add disabled=yes interval=30s name=schedule1 on-event=dyndns policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/01/1970 start-time=00:00:00
add disabled=yes interval=1m name=schedule2 on-event=changeip policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=may/23/2014 start-time=17:35:09
/system script
add name=dyndns policy=ftp,reboot,read,write,policy,test,winbox,password,sensitive source=":local atualipservervpn [:resolve \"ts.hsystem.com.br\"]\r\
\n:log info \"Atual IP do servidor VPN: \$atualipservervpn\"\r\
\n\r\
\n\r\
\n:local ipcadastradoservervpn [/interface pptp-client get value-name=connect-to pptp-out1]\r\
\n:log info \"IP cadastrado do servidor VPN: \$ipcadastradoservervpn\"\r\
\n\r\
\n\r\
\n:if (\$atualipservervpn != \$ipcadastradoservervpn) do={interface pptp-client set pptp-out1 connect-to=\$atualipservervpn\r\
\n:log info \"Configuracao de VPN alterada\"}"
add name=changeip policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api source="# Dynamic DNS Update / Simple Edition\r\
\n# Written by Sam Norris, ChangeIP.com\r\
\n# Copyright ChangeIP.com 2009-2010\r\
\n# For support send mail to
Support@ChangeIP.com\r\
\n#\r\
\n# 2009-06-22 RouterOS 3.25 Tested\r\
\n# 2009-10-05 RouterOS 4.01rc1 Tested\r\
\n#\r\
\n# OVERVIEW: %\r\
\n# This script will update a ChangeIP.com dynamic dns hostname\r\
\n# with an ip address located directly on an interface.\r\
\n# %\r\
\n# NOTES: %\r\
\n# IF THIS SCRIPT DOES NOT PRODUCE ANY OUTPUT PLEASE COPY AND PASTE IT\r\
\n# AGAIN. THERE PROBABLY IS A LINE BREAK IN THE WRONG PLACE! Once you\r\
\n# have created this script and tested that it works by running it\r\
\n# manually you can schedule it to run every few minutes.\r\
\n# %\r\
\n# CONFIGURATION FIELD DEFINITIONS:\r\
\n# ddnsuser: ChangeIP.com user id.\r\
\n# ddnspass: Enter your ChangeIP.com password.\r\
\n# ddnshost: Enter the hostname (
www.example.com) to update.\r\
\n# ddnsinterface: Enter an interface name - case sensative.\r\
\n# %\r\
\n# %\r\
\n# %\r\
\n# %\r\
\n# % % %\r\
\n# % % %\r\
\n# % % %\r\
\n# %\r\
\n# ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~\r\
\n# EDIT YOUR DETAILS / CONFIGURATION HERE\r\
\n:global ddnsuser \"
hugo_jammal@hotmail.com\"\r\
\n:global ddnspass \"mikrotikhu\"\r\
\n:global ddnshost \"hoteluniverso.changeip.net\"\r\
\n:global ddnsinterface \"CTBC\"\r\
\n# END OF USER DEFINED CONFIGURATION\r\
\n\r\
\n:global ddnssystem (\"mt-\" . [/system package get [/system package find name=system] version] )\r\
\n:global ddnsip [ /ip address get [/ip address find interface=\$ddnsinterface] address ]\r\
\n:global ddnslastip\r\
\n\r\
\n:if ([:len [/interface find name=\$ddnsinterface]] = 0 ) do={ :log info \"DDNS: No interface named \$ddnsinterface, please check configuration.\" }\r\
\n\r\
\n:if ([ :typeof \$ddnslastip ] = \"nothing\" ) do={ :global ddnslastip 0.0.0.0/0 }\r\
\n\r\
\n:if ([ :typeof \$ddnsip ] = \"nothing\" ) do={\r\
\n\r\
\n:log info (\"DDNS: No ip address present on \" . \$ddnsinterface . \", please check.\")\r\
\n\r\
\n} else={\r\
\n\r\
\n :if (\$ddnsip != \$ddnslastip) do={\r\
\n\r\
\n :log info \"DDNS: Sending UPDATE!\"\r\
\n :log info [ :put [/tool dns-update name=\$ddnshost address=[:pick \$ddnsip 0 [:find \$ddnsip \"/\"] ] key-name=\$ddnsuser key=\$ddnspass ] ]\r\
\n :global ddnslastip \$ddnsip\r\
\n\r\
\n } else={ \r\
\n\r\
\n :log info \"DDNS: No changes necessary.\"\r\
\n\r\
\n }\r\
\n\r\
\n}\r\
\n\r\
\n# END OF SCRIPT"
/tool graphing interface
add
add
/tool graphing resource
add
/tool netwatch
add comment="Monitorar internet" down-script="/system script run DOWN-LINK \\r\\n" host=8.8.8.8 interval=5s up-script=\
"=/system scheduler enabled [/system scheduler find name=remover_dns_dinamico]\\r\\n/ system script run LINK-UP\\r\\n"
