MUM Europe 2020
fxwireless
x86 ROS 4.17 to 6.14?
Wed Jun 11, 2014 2:00 pm
Hi!,
I've got my core router running v4.17 looking to upgrade finally, I wanted to know if I should first upgrade to 5.xx or I can directly upgrade to the newest 6.xx?
Thanks.
rextended
Re: x86 ROS 4.17 to 6.14?
Wed Jun 11, 2014 2:16 pm
NO!!!
Exec exactly this, after a GOOD BACKUP:
update to 5.26 with routeros-x86-5.26.npk package, if you have extra NTP Server, KVM or user-manager remember to download it and install!!!
update to 6.7 (where is? replace 6.14 to 6.7 on download links) with routeros-x86-6.7.npk package, if you have extra NTP Server, KVM or user-manager remember to download it and install!!!
IF YOU HAVE PPPOE-SERVER RUNNING INSIDE THE DEVICE, I SUGGEST YOU TO NOT PROCEED OVER...
but if you want, finally update to 6.14 with button check for updates on system / packages
I'm Italian, not English. Sorry for my imperfect grammar.
fxwireless
Wed Jun 11, 2014 2:27 pm
Thanks, rextended!
Users browsing this forum: No registered users and 102 guests
