MUM Europe 2020
minda
openvpn iOS tls failed
Sun Jul 06, 2014 1:53 pm
Something changed since routeros v6.9. Now is not possible connect to mikrotik openvpn from IOS (iPhone) openvpn client ("disconnected <TLS failed>" error).
No problems detected connecting from viscosity (osx) or openvpn (linux terminal).
I have tried different ciphers and other configurations, but no success.
Tested routeros versions:
6.7 working
6.9 no
6.10 no
6.11 no
6.12 no
6.13 no
6.14 no
6.15 no
isabido
Re: openvpn iOS tls failed
Mon Jul 14, 2014 7:56 pm
It is exactly the same problem. With version 6.7 works, but the last build 6.16 does not work.
That may be happening?
praiafrances
Fri Jul 18, 2014 11:02 am
same problem, I have 2 Router RB751U-2HnD , are connected with OPENVPN, the client is 6.15, the server 6.7, if I upgrade the server with 6.9 ->6.15 don't work.
Test471
Tue Jul 22, 2014 11:30 pm
patrickmkt
Tue Jul 22, 2014 11:47 pm
It's not only ios. I can't connect anymore from windows GUI with a config that was operational before.
See http://forum.mikrotik.com/viewtopic.php?f=2&t=87297
minda
Sat Aug 02, 2014 11:58 pm
I found solution and now iOS openvpn client v. (1.0.4 build 140) connects to mikrotik routeros v 6.18.
IOS settings->openvpn->advanced settings->Force AES-CBC ciphersuites (disabled this option).
Ciambot
Thu Aug 06, 2015 5:18 pm
Thanks, very useful.
neomega702
Wed May 04, 2016 1:01 am
Thanks a lot, you saved me!
Users browsing this forum: MSN [Bot] and 72 guests
