MUM Europe 2020
normis
v6.16 RC test release now includes 802.11ac support
Wed Jul 09, 2014 1:19 pm
We are happy to announce 802.11ac support in RouterOS. Before we make this a general release, we would like to give you, the forum users, the ability to test it first.
802.11ac support is enabled for QCA9880/9882 rev2 (-BR4A) wireless chipsets, and wireless-fp package must be used. It is included in the general combined package, no separate downoad necessary
Other changes:
What's new in 6.16 (2014-Jul-17 13:12):
*) winbox - fixed random disconnection over encrypted tunnels;
*) l2tp, pptp, pppoe - fixed possible packet corruption when encryption was enabled;
*) ovpn - fixed ethernet mode;
*) certificates - use SHA256 for fingerprinting;
*) ipsec - fix AH proposal and problem when sometimes policy was not generated;
*) snmp - support AES encryption (rfc3826);
*) l2tp server: added option to enable IPsec automatically;
*) poe-out: added power-cycle-ping and power-cycle-interval settings;
*) gps - increased retry duration to 30 seconds;
*) time - on routerboards, current time is saved in configuration on reboot
and on clock adjustment, and is used to set initial time after reboot;
*) sntp - disabling/enabling client was causing dynamic-servers to be ignored
(bug introduced in 6.14);
*) CCR - fixed rare file system corruption when none
of configuration could be changed or some of it disappeared;
*) ipsec - allow multiple encryption algorithms per peer;
*) email - support tls only connections;
*) smb - fixed usb share issues after reboot
*) snmp - fix v3 protocol time window checks;
*) updated timezone information;
*) quickset - added VPN settings for HomeAP mode;
*) latency improvements on CCR devices;
Download links
CCR: http://www.mikrotik.com/download/share/ ... latest.npk
MIPS-BE: http://www.mikrotik.com/download/share/ ... latest.npk
MIPS-LE: http://www.mikrotik.com/download/share/ ... latest.npk
PPC: http://www.mikrotik.com/download/share/ ... latest.npk
x86: http://www.mikrotik.com/download/share/ ... latest.npk
ALL file ZIP: http://www.mikrotik.com/download/share/ ... latest.zip
onnoossendrijver
Re: v6.16 RC test release now includes 802.11ac support
Wed Jul 09, 2014 1:34 pm
Do you support only the v2 cards (-AR4A ?) and not the v1 cards (-AR1A?), like many other AC implementations?
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
normis
Wed Jul 09, 2014 1:39 pm
AR1A
no, we do not support v1 cards, only Peregrin v2
Shiro
Wed Jul 09, 2014 2:20 pm
i updated my RB493G (running as AP) from 6.15 and got a reboot loop. On the serial console i see no error, just repeating boot/login prompt and a reboot around 5-10 sec after the boot . No chance to get a supout :/
MikroTik 6.16rc17
mtr17 Login:
RouterBOOT booter 3.10
RouterBoard 493G
CPU frequency: 680 MHz
Memory size: 256 MiB
NAND size: 128 MiB
NAND partitions: 2
Press any key within 5 seconds to enter setup.
Update: ok was able to login fast enough and get this:
01:00:43 system,info,account user xxx logged in via local
[xxx@mtr17] /log>
echo: system,error,critical System rebooted because of kernel failure
It looks like a Ethernet issue, as soon as i plug in Ethernet, the kernel crashes after short moment after the auto Negotiation. Wireless connection is ok.
I was able to get the autosupout file and made a Ticket to MT, id is: Ticket#2014070966000634
rextended
Wed Jul 09, 2014 3:09 pm
missing on changelog:
*) user-manager - now profile and limitation can be added / imported correctly for each owner;
I'm Italian, not English. Sorry for my imperfect grammar.
sergejs
Wed Jul 09, 2014 4:24 pm
Shiro, thank you very much for very fast report.
Now there is updated 6.16rc version available from the same links, that has fix for RB4xx boards.
We will be happy to receive feedback on this version.
Shiro
Wed Jul 09, 2014 5:10 pm
Hi Sergejs,
i installed RC18 and the issue is gone.
Thanks for the fast update :)
Sven
docmarius
Wed Jul 09, 2014 5:29 pm
Looking stable and all working OK on first glance on PPC (RB1100AHx2).
Date/Time save feature works nicely. Tnx.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
Engitech
Trainer
Trainer
Wed Jul 09, 2014 5:40 pm
Tested on RB912G-2HnD and 802.11ac QCA9880 mini-pcie card. Seems works well - 702 mbps udp between 2 of these.
Stable on bandwith test 1 hour.
Good job.
docmarius
Wed Jul 09, 2014 6:07 pm
On CRS-125-24G-1S firmware 6.16rc18 kills the primary bootloader (3.17 - no message on the serial console, no access, nothing on the display, just the switch chip working and usr1 LED blinking fast).
It starts up correctly with the backup(3.08) and is working.
Reverted to 6.15 and still no boot with the primary. After rewriting the primary bootloader from 6.15 (3.16) everything is back to normal.
paoloaga
Wed Jul 09, 2014 6:14 pm
I think that giving the opportunity to test the latest RC a few days before publishing a new release is a great idea! People can test the system on non critical devices...
honzam
Wed Jul 09, 2014 6:39 pm
:) Thanks for support 802.11ac :)
LAN, FTTx, Wireless. ISP operator
Shiro
Wed Jul 09, 2014 7:22 pm
I tested 6.16rc18 on following devices:
CCR-1009-8G-1S-1S+
RB493G
x86
So far no issues.
Tested this on CCR and x86:
At first, i expected that it forces the client to do ipsec for a successfull connection, but it looks like, it just creates a peer entry for l2tp/ipsec.
Sadly can't find any Minipci based card with QCA9880/9882 Chipset, only Minipci-e
Rowan
Wed Jul 09, 2014 8:30 pm
Any idea where I can buy the QCA9880/9882 rev2?
What antennas are people using?
Many thanks
R
Lupin
Thu Jul 10, 2014 12:10 am
Good job.
Can you share other informations?
Like: distance, signal, channel, modulation (256 qam??), ping, protocol..nv2 ?!!?
and some screenshots?
111111
Thu Jul 10, 2014 11:17 am
Isn't time to have demo3.mt.lv
with some new board as RB953GS-5HnT + 802.11AC card
with some continuous traffic
by the way is there will have antennas with 3 polarisations for 3 chain cards
for example mANT30 x3
In God We Trust. All other must submit X.509 certificate!
sergejs
Thu Jul 10, 2014 11:28 am
111111, you are 100% correct. We are preparing new demo routers, instead of current ones with AC cards and links. Thank you very much for the interest.
111111
Thu Jul 10, 2014 12:22 pm
10x for understand maby all products must have sub-domains
ex RB953GS-5HnT.mt.lv
and connected each other by all possible scenarios
ex. MESH, bridge, BGP, OSPF, GSM network etc.
Kickoleg
Thu Jul 10, 2014 1:30 pm
Waiting for SXT - Sextant with AC support and BaseBox ...
MTCNA, MTCUME, MTCRE, MTCWE, MTCTCE certified
sgxluk
Thu Jul 10, 2014 11:56 pm
Does this release fix port flapping? Don't bother releasing it without
gjnardoni
Fri Jul 11, 2014 6:14 am
Is it able to test 802.11ac on SXT?, if so, how to?
Regards
honzam
Fri Jul 11, 2014 9:52 am
Is it able to test 802.11ac on SXT?, if so, how to? Regards
And you have SXT ac?
djdrastic
Fri Jul 11, 2014 10:23 am
Good job.
Hi Engitech , would you mind sharing how many channels and what type of setup as well as wireless mode was being used ? Those results are very intriguing.
111111
Fri Jul 11, 2014 1:57 pm
When exactly will be on market RB911G-5HPacD aka BaseBox5
gjnardoni
Fri Jul 11, 2014 3:02 pm
honzam, I really don't know, actually, if SXT is .ac compatible, that's why I'm asking for...
Could you please help how to identify its hardware, if it supports?
Engitech
Trainer
Trainer
Fri Jul 11, 2014 3:25 pm
I will try to post more information this week-end - no time now. But the setup was very basic. I do it only to see if the card that i have were compatible with new drivers. 3 channels used, omni mikrotik pigtail antenna , on a desk about 1 meter of distance - wifi signal registration indicated 1333Mb/sec.
honzam
You need SXTG-5HacD. The AC is in the name of product. Actualy is in NOT on market.
See PDF brochure: http://forum.mikrotik.com/viewtopic.php ... 54#p435757
djdrastic
Fri Jul 11, 2014 3:35 pm
Much appreciated.
gjnardoni
Fri Jul 11, 2014 4:29 pm
Thank you!.
Shiro
Fri Jul 11, 2014 6:10 pm
AES option is missing in Winbox but available on console.
jose
Fri Jul 11, 2014 11:01 pm
Engitech
Where did you got the ac cards?
What brand?
honzam
Sat Jul 12, 2014 2:13 pm
shed
Sat Jul 12, 2014 4:55 pm
I can't find 802.11ac interface.
- D-Link DWA-182
- Intel 7260
- QCA9880-BR4A
What is the problem?
cdemers
Sat Jul 12, 2014 5:04 pm
Are you using the wireless-fp package and not the regular one?
Sent from my Nexus 5 using Tapatalk
shed
Sat Jul 12, 2014 5:25 pm
It was installed wireless-fp package.
How do it use Wireless-fp package?
npero
Sat Jul 12, 2014 6:33 pm
Go to System Package mark wireless-fp and click on button enable. After that must go to System Reboot and after reboot package is active.
wispwest
Sun Jul 13, 2014 12:37 am
can anyone post links to purchase the cards that are supported for 802.11ac?
also from the looks on google, this particular card is a mini-PCIe??? whey did they chose these smaller, lower power cards with non-MCX ports? Ughh.....
honzam
Sun Jul 13, 2014 9:47 am
all cards with: QCA9880/9882 rev2 (-BR4A)
for example http://www.compexshop.com/index.php/cPath/57_103
napismizpravu
Re: v6.16 RC test release - samba error
Sun Jul 13, 2014 1:51 pm
sdílení funkční několik minut od restartu na RB433UAH (6.16rc18) a pak nedostupný...služba zkolabovala
share functional for several minutes and then restart unavailable ...services smb broken,collapsed (usb lost proxy Cache Drive) ... FTP > USBx functional
Ehman
Mon Jul 14, 2014 6:38 pm
3g dongle K3772-Z been added yet?
jose
Mon Jul 14, 2014 6:54 pm
Yes, Would like to know too.
normis
Tue Jul 15, 2014 9:07 am
Netbox 5 is already available to distributors, so should reach end users soon
waldeir
Tue Jul 15, 2014 9:48 pm
RBSXTG-5HPACD LITE version also will be available?
lix5027
Wed Jul 16, 2014 3:10 am
6.13, 14, 15,16rc
ccr 1032
userman always crash. I don't know why.
People can not login, the hotspot said "no user". Only I can do is just restart.
BTW,
Looking forward to have ovpn with IPV6 tunnel in the new version. (ipv4 is not stable, v6 llink is much better then v4) :)
presianbg
Wed Jul 16, 2014 5:58 pm
I updated my RB2011UiAS-2HnD-IN with routeros-mipsbe-6.16rc18.npk and found 1 problem. When i reboot the router hangs and LCD display is blank (white). Solution is to hardware reset, then it's ok ? Any ideas?
10x in advance.
Best Regards,
Pressian
rextended
Wed Jul 16, 2014 6:19 pm
10x in advance.
Best Regards,
Pressian
Have exact model on office and at house, no problem.
EXACT method used for update/upgrade?
presianbg
Wed Jul 16, 2014 7:42 pm
10x in advance.
Best Regards,
Pressian
Yep, via WinBox -> System -> Packages -> drag and drop .npk file -> reboot.
EDIT: Tried to upgrade it again with routeros-mipsbe-6.16.npk and problem is gone. :)
rwaters
Thu Jul 17, 2014 4:19 am
RB912UAG-2HPnD using Compex WLE900VX advertised as Atheros QCA9880 v2. I do get wlan2 and can connect to it but rx rate limited to 6Mb and not supported to change tx power to "card rates". btest client shows tx at 5Mb and rx getting just over 200Mb udp throughput going from laptop through rb912 to ccr1009.
from terminal the information from "interface wireless print":
1 R name="wlan2" mtu=1500 mac-address="redacted" arp=enabled
interface-type=Atheros AR9888 mode=ap-bridge ssid="redacted"
frequency=auto band=5ghz-onlyac channel-width=20/40/80mhz-eCee
scan-list=default wireless-protocol=any vlan-mode=no-tag vlan-id=1
wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no
bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
could be this card not fully supported but I share my experience so far
Keep up the good work!
Shiro
Thu Jul 17, 2014 1:17 pm
the (final?) 6.16 on the servers still missing the AES Encryption option in Winbox and WebUI.
andriys
Thu Jul 17, 2014 2:31 pm
I'd say it is normal/expected. In the previous 6.x releases lots of new features were added as CLI-only first, with GUI support being added several releases after.
janisk
Thu Jul 17, 2014 3:11 pm
you will be able to select AES as an option using winbox when 6.16 is released.
visalink
Thu Jul 17, 2014 6:06 pm
The last 6.16 fix this.
tomaskir
Trainer
Trainer
Fri Jul 18, 2014 3:20 pm
Since v6.16 has now been released, this topic should probably not be a sticky announcement anymore ;)
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
Users browsing this forum: Cartagena, Google [Bot], ilja, SiB and 131 guests
