kraic
[SOLVED] please solve 10Mbps ethernet problem
Fri Jul 11, 2014 12:05 am
please solve 10Mbps ethernet problem because I have 7 Rb1100x2Ah and I have problems on 4 off them.. that's tooo bad.. please solve it..
All time it's going from 10 to 100 then to 1Gb and again to 10... driving us crazy :?
rextended
Re: please solve 10Mbps ethernet problem
Fri Jul 11, 2014 1:10 am
Very well described problem, notice the part where you describe what routeros and bios [firmware] version you have.
Without ignoring the part where you describe what hardware you connect to RB1100AHx2 to get this problem.
This is sarcasm...?
I'm Italian, not English. Sorry for my imperfect grammar.
kraic
Mon Jul 28, 2014 6:17 pm
RB1100x2AH firm:3.10 RouterOS 6.17
Having problem with
RB411GL firm:3.18 RouterOS 6.17
3bs
Mon Jul 28, 2014 6:24 pm
+ sxt lite2 (after power down switch to 10mbit) only restart help. on all 6.x versions
WBR, 3bs =)
kraic
Sat Sep 06, 2014 8:36 pm
It seems that after changing ethernet cable to new Cat7 Shielded with shielded module, port flapping vanished :-)
MulderSk
Fri Sep 26, 2014 12:34 am
Hi I have same problem on several mikrotik You try cat6 ? or only cat7 solved problem ? thanks
Kreacher
Re: [SOLVED] please solve 10Mbps ethernet problem
Mon Sep 29, 2014 1:43 am
We where changing in the past all of our patch cables to CAT.6a, the length does no matter, we
changed all of them and the positive effect we where seeing was, that at all used MikroTik devices
many of the told above problems where gone from one to the other second.
Ok by the way we a re using S/SFTP cables as patch cables now.
Hardware from other vendors was not infected by this problem.
Kindly regards
Kreacher ♬
Karma points must not be paid by you
panteraboy
Thu Nov 16, 2017 8:19 pm
Same problem on SXT Lite 5 , after several restarts, it connects to 100mb
RB750, RB433AH, RB2011RM
Users browsing this forum: dade80vr, SiB and 88 guests
