Ivoshiee
LTE + invalid PIN resulting a locked PIN
Sat Jul 12, 2014 12:02 am
Earlier attempts on older ROS to put in an invalid PIN did nothing more that one attempt to set it and fail with a notice into the log, but the v6.15 with LTE moodule it kept on trying that invalid PIN and after 3rd one the SIM was locked - go and find a PUK and a phone.
I seek the restoration of the previous functionality. If the PIN is wrong at the first try, there is no need to commence it numerous times.
Btw: How to enter a PUK code under the ROS?
wpeople
Re: LTE + invalid PIN resulting a locked PIN
Sun Dec 24, 2017 4:25 pm
get off the card into a cellphone and unlock (and disable the SIM request)
rextended
Fri Jul 26, 2019 12:31 pm
If someone read this topics,
this is the solution to unlock the sim after 3 wrong pin.
Warning: after 10 wrong PUK the SIM is broken.
Replace on the example the right numbers on PUK and PIN
Code: Select all
/interface lte at-chat lte1 input="AT+CPIN=PUK,PIN"
I'm Italian, not English. Sorry for my imperfect grammar.
Users browsing this forum: eworm and 88 guests
