Ximi87
how to port forwarding from some routers to IP CAMERA
Sat Jul 12, 2014 5:05 pm
Hello
I have some IP camera in my network but from external IP to IP Camera i have some routers.
I have made a scheme and this is the true connection.
I think it will be with port forwarding.
Please help me
Kickoleg
Re: how to port forwarding from some routers to IP CAMERA
Sun Jul 13, 2014 9:50 am
1st. router 750
/ip firewall nat add chain=dstnat dst-address=80.91.xxx.xxx protocol=tcp dst-port=8088 action=dstnat to-address=192.168.4.2 to-port=8088
2.st router Omnitik
/ip firewall nat add chain=dstnat dst-address=192.168.4.2 protocol=tcp dst-port=8088 action=dstant to-address=10.10.10.20 to-port=8088
3.st router SXT
/ip firewall nat add chain=dstnat dst-address=10.10.10.20 protocol=tcp dst-port=8088 action=dstnat to-address-192.168.103.99 to-port=80
*port 8088 - for example, you may choose other ...
MTCNA, MTCUME, MTCRE, MTCWE, MTCTCE certified
Ximi87
Tue Jul 15, 2014 12:28 am
Thanks man. it works :)
Thankyou very much
jkarras
Tue Jul 15, 2014 6:16 am
Three NAT statements are only needed if you are not routing all of the connections in your network. You should only need the NAT statement on the first device connected to the Internet.
Users browsing this forum: No registered users and 83 guests
