MUM Europe 2020
denisun
PPPoE Client + IPv6
Wed Jul 16, 2014 7:16 pm
I have a Mikrotik RB951G-2HnD and i work with pppoe client with no problem.
My problem created when enable the ipv6 packet in pppoe client profile.
I noticed when my ether1 (my pppoe connection with my modem) drop then i have many efforts to connect with my ISP.
I have many connection and disconnection in minute and this situation repeating for 5-10 minutes until connection established.
My ipv6 connection work correctly but when the ether1 drop then i have the above problem.
My ether1 drop from brass when my ISP make updates (maybe 1 time of month or 2-3 times of day, i don't know the period).
I decide to make the tests manually and i drop ether1 manually changed the ethernet speed for example i disable 10M and live enable 100M speed.
This change drop the ether1.
When i have enable only ipv4 i don't have a problem.
My connection drop but reconnect immediately at once.
I believe maybe is bug of ROS 6.15.
I tried all the above in many other RouterBoard and i have the same result.
My ipv6 configuration are:
System > Package List > ipv6 (enable)
PPP > Profiles > default
	Protocols
		Use IPv6
			yes
		Use MPLS
			no
IPv6 > ND > Interfaces
	(all)
	Interface: pppoe-out1
	RA Interval: 10-30
	Advertise MAC Address
	Interface: bridge1
	RA Interval: 10-30
	Advertise DNS
IPv6 > ND > Prefixes
	Default:
		Valid Lifetime: 0d 00:05:00
		Preferred Lifetime: 0d 00:02:00
IPv6 > DHCPv6 Client (+)
	Pool Name: ipv6-pool
	(X) Use Peer DNS
	(X) Add Default Route
IPv6 > Addresses (+)
	Address: ::/64
	From Pool: ipv6-pool
	Interface: bridge1
	Advertise
IP > Routes > Routes > (+)
	General:
		Dst. Address: ::/0
		Gateway: pppoe-out1
The screenshots of my logs are:
https://imageshack.com/i/iqd3e158p
https://imageshack.com/i/km8b693bp
https://imageshack.com/i/ip112903p
Sorry for my English...
"What one programmer can do in one month, two programmers can do in two months."
Fred Brooks...
denisun
Re: PPPoE Client + IPv6
Fri Jul 18, 2014 6:24 pm
Anyone?
Fred Brooks...
denisun
Thu Jul 24, 2014 10:47 pm
Here it is a normal ipv6 pppoe client connection:
08:24:18 pppoe,ppp,info pppoe-out1: initializing...
08:24:18 pppoe,ppp,info pppoe-out1: connecting...
08:24:18 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
08:24:18 pppoe,debug,packet     session-id=0x0000
08:24:18 pppoe,debug,packet     host-uniq=0x34f0001
08:24:18 pppoe,debug,packet     service-name=
08:24:18 pppoe,debug,packet ether1: rcvd PADO from 00:90:1A:42:XX:YY
08:24:18 pppoe,debug,packet     ac-name=bras-ermX-YYYY
08:24:18 pppoe,debug,packet     ac-cookie=32 83 ac 4f 7a 84 18 26 96 2f d8 bf e0 33 93 9c
08:24:18 pppoe,debug,packet ether1: sent PADR to 00:90:1A:42:XX:YY
08:24:18 pppoe,debug,packet     host-uniq=0x34f0002
08:24:18 pppoe,debug,packet ether1: rcvd PADS from 00:90:1A:42:XX:YY
08:24:18 pppoe,debug,packet     session-id=0x3ab4
08:24:18 pppoe,ppp,debug pppoe-out1: LCP lowerup
08:24:18 pppoe,ppp,debug pppoe-out1: LCP open
08:24:18 pppoe,ppp,debug pppoe-out1: LCP timer
08:24:18 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfReq id=0x1
08:24:18 pppoe,ppp,debug,packet    <mru 1492>
08:24:18 pppoe,ppp,debug,packet    <magic 0x68d959c6>
08:24:18 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfReq id=0xce
08:24:18 pppoe,ppp,debug,packet    <magic 0x25429792>
08:24:18 pppoe,ppp,debug,packet    <auth pap>
08:24:18 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfAck id=0xce
08:24:18 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfAck id=0x1
08:24:18 pppoe,ppp,debug pppoe-out1: LCP opened
08:24:18 pppoe,ppp,debug,packet  pppoe-out1: sent PAP AuthReq id=0x1
08:24:18 pppoe,ppp,debug,packet     <user myusr@otenet.gr>
08:24:18 pppoe,ppp,debug,packet     <password mypsw>
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: rcvd PAP AuthAck id=0x1
08:24:19 pppoe,ppp,info pppoe-out1: authenticated
08:24:19 pppoe,ppp,debug pppoe-out1: IPCP lowerup
08:24:19 pppoe,ppp,debug pppoe-out1: IPCP open
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x1
08:24:19 pppoe,ppp,debug,packet     <addr 0.0.0.0>
08:24:19 pppoe,ppp,debug pppoe-out1: IPV6CP lowerup
08:24:19 pppoe,ppp,debug pppoe-out1: IPV6CP open
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfReq id=0x1
08:24:19 pppoe,ppp,debug,packet     <interface-identifier 0:0:0:9>
08:24:19 pppoe,ppp,debug pppoe-out1: MPLSCP open
08:24:19 pppoe,ppp,debug pppoe-out1: BCP open
08:24:19 pppoe,ppp,debug pppoe-out1: CCP lowerup
08:24:19 pppoe,ppp,debug pppoe-out1: CCP open
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfNak id=0x1
08:24:19 pppoe,ppp,debug,packet     <addr 85.75.49.XX>
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x2
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfAck id=0x1
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfAck id=0x2
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfReq id=0xf1
08:24:19 pppoe,ppp,debug,packet     <addr 80.106.108.XX>
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfAck id=0xf1
08:24:19 pppoe,ppp,debug pppoe-out1: IPCP opened
08:24:19 pppoe,ppp,info pppoe-out1: connected
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfReq id=0xf4
08:24:19 pppoe,ppp,debug,packet     <interface-identifier 90:1a00:142:XXXX>
08:24:19 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfAck id=0xf4
08:24:19 pppoe,ppp,debug pppoe-out1: IPV6CP opened
Here it is a normal disconnection (when i disable pppoe client manually):
08:24:59 pppoe,ppp,debug pppoe-out1: LCP close
08:24:59 pppoe,ppp,debug pppoe-out1: LCP closed
08:24:59 pppoe,ppp,debug pppoe-out1: CCP lowerdown
08:24:59 pppoe,ppp,debug pppoe-out1: BCP lowerdown
08:24:59 pppoe,ppp,debug pppoe-out1: BCP down event in starting state
08:24:59 pppoe,ppp,debug pppoe-out1: IPCP lowerdown
08:24:59 pppoe,ppp,debug pppoe-out1: IPCP closed
08:24:59 pppoe,ppp,debug pppoe-out1: IPV6CP lowerdown
08:24:59 pppoe,ppp,debug pppoe-out1: IPV6CP closed
08:24:59 pppoe,ppp,debug pppoe-out1: MPLSCP lowerdown
08:24:59 pppoe,ppp,debug pppoe-out1: MPLSCP down event in starting state
08:24:59 pppoe,ppp,debug,packet  pppoe-out1: sent LCP TermReq id=0x2
08:24:59 pppoe,ppp,debug,packet     administrator request
08:24:59 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP TermAck id=0x2
08:24:59 pppoe,ppp,debug pppoe-out1: LCP lowerdown
08:24:59 pppoe,ppp,info pppoe-out1: terminating... - administrator request
08:24:59 pppoe,debug,packet ether1: sent PADT to 00:00:00:00:00:00
08:24:59 pppoe,debug,packet     session-id=0x3ab4
08:24:59 pppoe,ppp,debug pppoe-out1: LCP down event in initial state
08:24:59 pppoe,ppp,info pppoe-out1: disabled
And this is my problem...
When ipv6 pppoe client is connected i do this test:
I change my ether1 speed (in ether1 is connected the modem) (manually drop ether1).
Then i have many connection and disconnection for a long time.
This is my log:
08:29:45 interface,info ether1 link down
08:29:48 pppoe,ppp,info pppoe-out1: terminating... - disconnected
08:29:48 pppoe,ppp,debug pppoe-out1: LCP lowerdown
08:29:48 pppoe,ppp,debug pppoe-out1: LCP down event in starting state
08:29:48 pppoe,ppp,info pppoe-out1: disconnected
08:29:48 pppoe,ppp,info pppoe-out1: initializing...
08:29:48 pppoe,ppp,info pppoe-out1: connecting...
08:29:48 interface,info ether1 link up (speed 10M, full duplex)
08:29:49 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
08:29:49 pppoe,debug,packet     session-id=0x0000
08:29:49 pppoe,debug,packet     host-uniq=0x35c0004
08:29:49 pppoe,debug,packet     service-name=
08:29:49 pppoe,debug,packet ether1: rcvd PADO from 00:90:1A:42:XX:YY
08:29:49 pppoe,debug,packet     ac-name=bras-ermX-YYYY
08:29:49 pppoe,debug,packet     ac-cookie=32 83 ac 4f 7a 84 18 26 96 2f d8 bf e0 33 93 9c
08:29:49 pppoe,debug,packet ether1: sent PADR to 00:90:1A:42:XX:YY
08:29:49 pppoe,debug,packet     host-uniq=0x35c0005
08:29:49 pppoe,debug,packet ether1: rcvd PADS from 00:90:1A:42:XX:YY
08:29:49 pppoe,debug,packet     session-id=0x0151
08:29:49 pppoe,ppp,debug pppoe-out1: LCP lowerup
08:29:49 pppoe,ppp,debug pppoe-out1: LCP open
08:29:49 pppoe,ppp,debug pppoe-out1: LCP timer
08:29:49 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfReq id=0x2
08:29:49 pppoe,ppp,debug,packet    <mru 1492>
08:29:49 pppoe,ppp,debug,packet    <magic 0x435e978e>
08:29:49 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfReq id=0x99
08:29:49 pppoe,ppp,debug,packet    <magic 0x28aa5378>
08:29:49 pppoe,ppp,debug,packet    <auth pap>
08:29:49 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfAck id=0x99
08:29:49 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfAck id=0x2
08:29:49 pppoe,ppp,debug pppoe-out1: LCP opened
08:29:49 pppoe,ppp,debug,packet  pppoe-out1: sent PAP AuthReq id=0x2
08:29:49 pppoe,ppp,debug,packet     <user myusr@otenet.gr>
08:29:49 pppoe,ppp,debug,packet     <password mypsw>
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd PAP AuthAck id=0x2
08:29:50 pppoe,ppp,info pppoe-out1: authenticated
08:29:50 pppoe,ppp,debug pppoe-out1: IPCP lowerup
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x3
08:29:50 pppoe,ppp,debug,packet     <addr 0.0.0.0>
08:29:50 pppoe,ppp,debug pppoe-out1: IPCP open
08:29:50 pppoe,ppp,debug pppoe-out1: IPV6CP lowerup
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfReq id=0x2
08:29:50 pppoe,ppp,debug,packet     <interface-identifier 0:0:0:9>
08:29:50 pppoe,ppp,debug pppoe-out1: IPV6CP open
08:29:50 pppoe,ppp,debug pppoe-out1: MPLSCP open
08:29:50 pppoe,ppp,debug pppoe-out1: BCP open
08:29:50 pppoe,ppp,debug pppoe-out1: CCP lowerup
08:29:50 pppoe,ppp,debug pppoe-out1: CCP open
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfNak id=0x3
08:29:50 pppoe,ppp,debug,packet     <addr 94.68.193.XXX>
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x4
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfAck id=0x2
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfAck id=0x4
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfReq id=0x4a
08:29:50 pppoe,ppp,debug,packet     <addr 80.106.108.YY>
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfAck id=0x4a
08:29:50 pppoe,ppp,debug pppoe-out1: IPCP opened
08:29:50 pppoe,ppp,info pppoe-out1: connected
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfReq id=0x35
08:29:50 pppoe,ppp,debug,packet     <interface-identifier 90:1a00:142:XXXX>
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfAck id=0x35
08:29:50 pppoe,ppp,debug pppoe-out1: IPV6CP opened
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP TermReq id=0x36
08:29:50 pppoe,ppp,debug pppoe-out1: IPV6CP closed
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP TermAck id=0x36
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP TermReq id=0x9a
08:29:50 pppoe,ppp,debug pppoe-out1: LCP closed
08:29:50 pppoe,ppp,debug pppoe-out1: CCP lowerdown
08:29:50 pppoe,ppp,debug pppoe-out1: BCP lowerdown
08:29:50 pppoe,ppp,debug pppoe-out1: BCP down event in starting state
08:29:50 pppoe,ppp,debug pppoe-out1: IPCP lowerdown
08:29:50 pppoe,ppp,debug pppoe-out1: IPCP closed
08:29:50 pppoe,ppp,debug pppoe-out1: IPV6CP lowerdown
08:29:50 pppoe,ppp,debug pppoe-out1: MPLSCP lowerdown
08:29:50 pppoe,ppp,debug pppoe-out1: MPLSCP down event in starting state
08:29:50 pppoe,ppp,debug,packet  pppoe-out1: sent LCP TermAck id=0x9a
08:29:50 pppoe,ppp,debug pppoe-out1: LCP lowerdown
08:29:50 pppoe,ppp,info pppoe-out1: terminating...
08:29:50 pppoe,debug,packet ether1: sent PADT to 00:00:00:00:00:00
08:29:50 pppoe,debug,packet     session-id=0x0151
08:29:50 pppoe,ppp,debug pppoe-out1: LCP down event in starting state
08:29:50 pppoe,ppp,info pppoe-out1: disconnected
08:29:50 pppoe,debug,packet ether1: rcvd PADT from 00:90:1A:42:XX:YY
08:29:51 pppoe,ppp,info pppoe-out1: initializing...
08:29:51 pppoe,ppp,info pppoe-out1: connecting...
08:29:51 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
08:29:51 pppoe,debug,packet     session-id=0x0000
08:29:51 pppoe,debug,packet     host-uniq=0x35c0006
08:29:51 pppoe,debug,packet     service-name=
08:29:51 pppoe,debug,packet ether1: rcvd PADO from 00:90:1A:42:XX:YY
08:29:51 pppoe,debug,packet     ac-name=bras-ermX-YYYY
08:29:51 pppoe,debug,packet     ac-cookie=32 83 ac 4f 7a 84 18 26 96 2f d8 bf e0 33 93 9c
08:29:51 pppoe,debug,packet ether1: sent PADR to 00:90:1A:42:XX:YY
08:29:51 pppoe,debug,packet     host-uniq=0x35c0007
08:29:51 pppoe,debug,packet ether1: rcvd PADS from 00:90:1A:42:XX:YY
08:29:51 pppoe,debug,packet     session-id=0x017a
08:29:51 pppoe,ppp,debug pppoe-out1: LCP lowerup
08:29:51 pppoe,ppp,debug pppoe-out1: LCP open
08:29:51 pppoe,ppp,debug pppoe-out1: LCP timer
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfReq id=0x3
08:29:51 pppoe,ppp,debug,packet    <mru 1492>
08:29:51 pppoe,ppp,debug,packet    <magic 0x5a51cec5>
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfReq id=0x15
08:29:51 pppoe,ppp,debug,packet    <magic 0x7589cdd8>
08:29:51 pppoe,ppp,debug,packet    <auth pap>
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfAck id=0x15
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfAck id=0x3
08:29:51 pppoe,ppp,debug pppoe-out1: LCP opened
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: sent PAP AuthReq id=0x3
08:29:51 pppoe,ppp,debug,packet     <user myusr@otenet.gr>
08:29:51 pppoe,ppp,debug,packet     <password mypsw>
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: rcvd PAP AuthAck id=0x3
08:29:51 pppoe,ppp,info pppoe-out1: authenticated
08:29:51 pppoe,ppp,debug pppoe-out1: IPCP lowerup
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x5
08:29:51 pppoe,ppp,debug,packet     <addr 0.0.0.0>
08:29:51 pppoe,ppp,debug pppoe-out1: IPCP open
08:29:51 pppoe,ppp,debug pppoe-out1: IPV6CP lowerup
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfReq id=0x3
08:29:51 pppoe,ppp,debug,packet     <interface-identifier 0:0:0:9>
08:29:51 pppoe,ppp,debug pppoe-out1: IPV6CP open
08:29:51 pppoe,ppp,debug pppoe-out1: MPLSCP open
08:29:51 pppoe,ppp,debug pppoe-out1: BCP open
08:29:51 pppoe,ppp,debug pppoe-out1: CCP lowerup
08:29:51 pppoe,ppp,debug pppoe-out1: CCP open
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfNak id=0x5
08:29:51 pppoe,ppp,debug,packet     <addr 85.75.53.XXX>
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x6
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfAck id=0x3
08:29:51 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfAck id=0x6
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfReq id=0x65
08:29:52 pppoe,ppp,debug,packet     <interface-identifier 90:1a00:142:XXXX>
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfAck id=0x65
08:29:52 pppoe,ppp,debug pppoe-out1: IPV6CP opened
08:29:52 pppoe,ppp,info pppoe-out1: connected
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfReq id=0x66
08:29:52 pppoe,ppp,debug,packet     <addr 80.106.108.YY>
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfAck id=0x66
08:29:52 pppoe,ppp,debug pppoe-out1: IPCP opened
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP TermReq id=0x66
08:29:52 pppoe,ppp,debug pppoe-out1: IPV6CP closed
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP TermAck id=0x66
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP TermReq id=0x16
08:29:52 pppoe,ppp,debug pppoe-out1: LCP closed
08:29:52 pppoe,ppp,debug pppoe-out1: CCP lowerdown
08:29:52 pppoe,ppp,debug pppoe-out1: BCP lowerdown
08:29:52 pppoe,ppp,debug pppoe-out1: BCP down event in starting state
08:29:52 pppoe,ppp,debug pppoe-out1: IPCP lowerdown
08:29:52 pppoe,ppp,debug pppoe-out1: IPCP closed
08:29:52 pppoe,ppp,debug pppoe-out1: IPV6CP lowerdown
08:29:52 pppoe,ppp,debug pppoe-out1: MPLSCP lowerdown
08:29:52 pppoe,ppp,debug pppoe-out1: MPLSCP down event in starting state
08:29:52 pppoe,ppp,debug,packet  pppoe-out1: sent LCP TermAck id=0x16
08:29:52 pppoe,ppp,debug pppoe-out1: LCP lowerdown
08:29:52 pppoe,ppp,info pppoe-out1: terminating...
08:29:52 pppoe,debug,packet ether1: sent PADT to 00:00:00:00:00:00
08:29:52 pppoe,debug,packet     session-id=0x017a
08:29:52 pppoe,ppp,debug pppoe-out1: LCP down event in starting state
08:29:52 pppoe,ppp,info pppoe-out1: disconnected
08:29:52 pppoe,debug,packet ether1: rcvd PADT from 00:90:1A:42:XX:YY
08:29:54 pppoe,ppp,info pppoe-out1: initializing...
08:29:54 pppoe,ppp,info pppoe-out1: connecting...
08:29:54 pppoe,debug,packet ether1: sent PADI to FF:FF:FF:FF:FF:FF
08:29:54 pppoe,debug,packet     session-id=0x0000
08:29:54 pppoe,debug,packet     host-uniq=0x35c0008
08:29:54 pppoe,debug,packet     service-name=
08:29:54 pppoe,debug,packet ether1: rcvd PADO from 00:90:1A:42:XX:YY
08:29:54 pppoe,debug,packet     ac-name=bras-ermX-YYYY
08:29:54 pppoe,debug,packet     ac-cookie=32 83 ac 4f 7a 84 18 26 96 2f d8 bf e0 33 93 9c
08:29:54 pppoe,debug,packet ether1: sent PADR to 00:90:1A:42:XX:YY
08:29:54 pppoe,debug,packet     host-uniq=0x35c0009
08:29:54 pppoe,debug,packet ether1: rcvd PADS from 00:90:1A:42:XX:YY
08:29:54 pppoe,debug,packet     session-id=0x0189
08:29:54 pppoe,ppp,debug pppoe-out1: LCP lowerup
08:29:54 pppoe,ppp,debug pppoe-out1: LCP open
08:29:54 pppoe,ppp,debug pppoe-out1: LCP timer
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfReq id=0x4
08:29:54 pppoe,ppp,debug,packet    <mru 1492>
08:29:54 pppoe,ppp,debug,packet    <magic 0x7242ea04>
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfReq id=0x6a
08:29:54 pppoe,ppp,debug,packet    <magic 0x74c51f60>
08:29:54 pppoe,ppp,debug,packet    <auth pap>
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent LCP ConfAck id=0x6a
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP ConfAck id=0x4
08:29:54 pppoe,ppp,debug pppoe-out1: LCP opened
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent PAP AuthReq id=0x4
08:29:54 pppoe,ppp,debug,packet     <user myusr@otenet.gr>
08:29:54 pppoe,ppp,debug,packet     <password mypsw>
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd PAP AuthAck id=0x4
08:29:54 pppoe,ppp,info pppoe-out1: authenticated
08:29:54 pppoe,ppp,debug pppoe-out1: IPCP lowerup
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x7
08:29:54 pppoe,ppp,debug,packet     <addr 0.0.0.0>
08:29:54 pppoe,ppp,debug pppoe-out1: IPCP open
08:29:54 pppoe,ppp,debug pppoe-out1: IPV6CP lowerup
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfReq id=0x4
08:29:54 pppoe,ppp,debug,packet     <interface-identifier 0:0:0:9>
08:29:54 pppoe,ppp,debug pppoe-out1: IPV6CP open
08:29:54 pppoe,ppp,debug pppoe-out1: MPLSCP open
08:29:54 pppoe,ppp,debug pppoe-out1: BCP open
08:29:54 pppoe,ppp,debug pppoe-out1: CCP lowerup
08:29:54 pppoe,ppp,debug pppoe-out1: CCP open
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfNak id=0x7
08:29:54 pppoe,ppp,debug,packet     <addr 85.75.54.0>
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfReq id=0x8
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfAck id=0x4
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfAck id=0x8
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPCP ConfReq id=0xb7
08:29:54 pppoe,ppp,debug,packet     <addr 80.106.108.YY>
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent IPCP ConfAck id=0xb7
08:29:54 pppoe,ppp,debug pppoe-out1: IPCP opened
08:29:54 pppoe,ppp,info pppoe-out1: connected
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: rcvd IPV6CP ConfReq id=0x66
08:29:54 pppoe,ppp,debug,packet     <interface-identifier 90:1a00:142:XXXX>
08:29:54 pppoe,ppp,debug,packet  pppoe-out1: sent IPV6CP ConfAck id=0x66
08:29:54 pppoe,ppp,debug pppoe-out1: IPV6CP opened
*** manual disable pppoe
08:29:55 pppoe,ppp,debug,packet  pppoe-out1: rcvd LCP TermReq id=0x6b
08:29:55 pppoe,ppp,debug pppoe-out1: LCP closed
08:29:55 pppoe,ppp,debug pppoe-out1: CCP lowerdown
08:29:55 pppoe,ppp,debug pppoe-out1: BCP lowerdown
08:29:55 pppoe,ppp,debug pppoe-out1: BCP down event in starting state
08:29:55 pppoe,ppp,debug pppoe-out1: IPCP lowerdown
08:29:55 pppoe,ppp,debug pppoe-out1: IPCP closed
08:29:55 pppoe,ppp,debug pppoe-out1: IPV6CP lowerdown
08:29:55 pppoe,ppp,debug pppoe-out1: IPV6CP closed
08:29:55 pppoe,ppp,debug pppoe-out1: MPLSCP lowerdown
08:29:55 pppoe,ppp,debug pppoe-out1: MPLSCP down event in starting state
08:29:55 pppoe,ppp,debug,packet  pppoe-out1: sent LCP TermAck id=0x6b
08:29:55 pppoe,ppp,debug pppoe-out1: LCP lowerdown
08:29:55 pppoe,ppp,info pppoe-out1: terminating...
08:29:55 pppoe,debug,packet ether1: sent PADT to 00:00:00:00:00:00
08:29:55 pppoe,debug,packet     session-id=0x0189
08:29:55 pppoe,ppp,debug pppoe-out1: LCP down event in starting state
08:29:55 pppoe,ppp,info pppoe-out1: disconnected
08:29:55 pppoe,debug,packet ether1: rcvd PADT from 00:90:1A:42:XX:YY
Fred Brooks...
Users browsing this forum: barracuda, richardsu, samimn and 100 guests
