MUM Europe 2020
fronczek
WinBox 3.0beta2 router selection and login
Fri Jul 18, 2014 5:11 pm
Can you restore setting when double-click on router list moves to password textbox rather than auto connect? ;)
Thanks!
rextended
Re: WinBox 3.0beta2 router selection and login
Fri Jul 18, 2014 7:55 pm
On double click is better as work now,
for copy just one click...
I'm Italian, not English. Sorry for my imperfect grammar.
macsrwe
Forum Veteran
Forum Veteran
Fri Jul 18, 2014 10:04 pm
Just installed winbox 3. When I launch it, it eats up one entire CPU until I quit it. It does what I ask it to, but my fans rev all the way up and it acts like it's mining bitcoins in the background. I'm running it on a Mac under Parallels, as I have always run winbox.
rextended
Fri Jul 18, 2014 10:55 pm
Use one true computer and you see no 100% cpu...
macsrwe
Forum Veteran
Forum Veteran
Fri Jul 18, 2014 11:03 pm
Not an option, unless you're buying.
The previous Winbox did not do this. No other Windows program under Parallels does this.
fronczek
Sat Jul 19, 2014 12:27 pm
But what if you don't have saved passwords? :>
It's not better in this case...
Maybe:
if password is saved: doubleclick = logon
else doubleclick goes to password box?
rextended
Sat Jul 19, 2014 2:32 pm
not, because password can be empty
keraia
Sun Jul 20, 2014 3:07 pm
Can't find any changelog. I installed it and cannot see any differences. What are the differences from previous version? Just bugfixes?
rextended
Sun Jul 20, 2014 11:43 pm
Where you download that?
Please continue this on official winbox 3 topic!
macsrwe
Forum Veteran
Forum Veteran
Mon Jul 21, 2014 12:47 am
Aaargh. I thought this WAS the official Winbox 3 topic. :-(
fronczek
Mon Jul 21, 2014 1:31 am
rextended, please consider that some people don't save passwords:
if I double click on a router with no passwod saved winbox3 goes with login procedure anyway - which always and with ERROR: wrong username or password
Can you tell me what is the point of that behavior? :>
In Winbox2 we have very useful and extremely fast path:
double click > focus to password box > enter password > hit enter > you're in
(only two mouse clicks at all)
In Winbox3 the procedure's logic is broken:
double click > ERROR: wrong username or password
ps. Where's the official topic? ;))
macsrwe
Forum Veteran
Forum Veteran
Mon Jul 21, 2014 1:48 am
I found it here:
http://forum.mikrotik.com/viewtopic.php ... 69#p437218
Users browsing this forum: Chupaka, jdejansb, Sob and 75 guests
