vdelarenal75
Winbox Font Size
Sun Jul 20, 2014 6:06 am
Hi, is there a way to increase the Font size in winbox? I recently bought a new laptop and it uses a higher resolution the text looks really small and if I increase the text size in Windows to 150% the text looks fuzzy.
jeroenp
Re: Winbox Font Size
Thu May 12, 2016 11:38 am
bump...
This is much needed especially on Hi-DPI displays used at native resolution.
--jeroen
normis
Thu May 12, 2016 12:43 pm
It works fine on HiDP displays if you use correct resolution (what the laptop manufacture suggests) and scaling settings in Windows (should be 100% where all looks best. but if it looks small, increasing this should not make it fuzzy).
Maybe you use an external display? Windows gets confused when the other display is not HiDP
macgaiver
Thu May 12, 2016 12:48 pm
i did reduce the resolution on the work laptop, to eliminate windows scaling fuzziness problems. (and that is not only winbox, that is an issue for many programs.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
jeroenp
Thu May 12, 2016 1:55 pm
It doesn't work fine when you use the Hi DPI displays to just have a lot of pixels. Which means no scaling and is a perfectly "correct resolution" (maybe not what "the laptop manufacture suggests", but a lot of companies suggest things that in practice work better when you do differently).
WinBox for for instance also fails on my 15 inch 1920x1200 and 1600x1200 screens. Yes, those screens have been available for a long time (for instance ThinkPad A20p around 2000, T61p around 2005, etc) and are still in use.
It is even too small on a 30" Iiyama PL3070WQ at 2560x1600 and fails miserably at my Retina MacBook at 2880x1620.
I like programs with small borders and larger fonts: makes much better use of screen real estate.
WinBox cannot do that but should.
normis
Thu May 12, 2016 2:04 pm
I don't agree. Macbook retina shows everything perfectly. Nothing should be small, the OS should do scaling by taking screen size into consideration, which seems is not the case in some Windows versions.
Screenshot from MacBook with Retina:
jeroenp
Thu May 12, 2016 3:03 pm
A screenshot on MacBook with Retina at 2880x1800 (see below) doesn't tell you much.
A photograph does:
The screenshot lures you into thinking it is readable until you realise this is at 220dpi: http://dpi.lv/#2880×1800@15.4
normis
Thu May 12, 2016 3:13 pm
Looks great to me. Font size consistent with System Preferences and other UI.
jeroenp
Thu May 12, 2016 4:59 pm
That's why it's not great. Most applications I use can be configured individually on font size to use. And that's also what vdelarenal75 asked for:
I understand that you guys are reluctant to add such a setting, but don't tell us "it's fine" when it clearly isn't for some of us.
--jeroen
PS: found a WineBottler workaround on OS X. It's not pretty, but gets me going. I've queued a blog post on it somewhere next summer.
normis
Fri May 13, 2016 8:49 am
OK, correction, it's not "fine", but it is the same as the rest of your system.
jeroenp
Fri May 13, 2016 6:06 pm
That isn't true either. Compare Atom IO text editor on the left and WinBox on the right.
I could make this picture on Windows as well (there is an Atom IO for Windows).
Put it in an extreme way: even Notepad on Windows can set the font size.
As a fellow software developer, I know font scaling and DPI support can be hard, but don't hide behind "it's the same as the rest of your system".
If you don't (yet) want to introduce font scaling in WinBox just tell us so.
--jeroen
teslasystems
Sat Feb 25, 2017 6:12 pm
Hello!
It's really need to improve WinBox compatibility with Windows scaling feature. For example, I'm using a 4K display with 4096x2160 resolution and 31.5" screen size and interface looks ugly when Windows scaling is not equal to 100%. But it's impossible to use Windows without scaling on such displays because everything is very small.
If I launch WinBox with standard settings, text is readable, but looks blurry. If I launch it with "Disable display scaling on high DPI settings" option, text looks better, but not everywhere. For example, the text in tables is clipped. I have attached screenshots to show you how it looks.
w01dnick
Sat Apr 22, 2017 1:02 pm
You are not quite corect while blaming Windows here and in other topics (like this one: viewtopic.php?t=85365).
Windows so called 100% DPI means 96 DPI, thats "standard" (in reality default, not standard) DPI done a lot of bad impact, because a lot of programmers used to it as to the only one DPI. 150% DPI in Windows doesn't mean it's something bad and non-standard, just monitor has not default 96 DPI but 144 DPI (or close to that, mine is 142 DPI).
Windows from old times can say current DPI to application. That's not something new. Application just have to ask it. OS X retina mode introducing some logical pixels not physical one for that bad written applications, that's one of they ways, bad way of this approach is that pixel is not really a pixel anymore. And current Windows 8/10 scaling is just a workaround for application that doesn't behave well with DPI. But it makes application blurry and just readable not well-readable anyway.
So it's not a Windows problem it is an application problem, it's not DPI aware (in Windows terms: https://msdn.microsoft.com/en-us/librar ... s.85).aspx).
If you are using WinAPI you could rely on good-old GetDeviceCaps(hDC, LOGPIXELSX) and GetDeviceCaps(hDC, LOGPIXELSY): https://msdn.microsoft.com/en-us/librar ... s.85).aspx. And yes, despite modern displays has square pixel that's not always true, they could be rectangular, but that's not too actual nowadays.
ffrauter
Thu Feb 08, 2018 8:53 am
Are there any news on this case?
I think we are not the only winbox-users, that are using 4k Displays.
Best Regards
Florian
haver
Wed Feb 14, 2018 5:41 pm
here is my problem with 4K monitor. How to fix ?
okoun
Fri Jan 11, 2019 11:08 pm
Hello, I have exactly the same problem 4K monitor has a lot of people today and it is only 2019. Please correct it for your applications, thanks
Joseph
Tue May 28, 2019 10:49 pm
Someone found a solution for crappy fonts?
I'ts a native Windows application, and it doesn't look correctly...
Linux and wine... it's terrible.
Shame on you MikroTik
krafg
Long time Member
Long time Member
Thu May 30, 2019 8:09 am
So hard is using a magnify tool to this? (Software obviously, not a real one).
Regards.
If you want to know my network, you can find it here.
marathoneer
Thu Feb 06, 2020 4:32 pm
Mikrotik DEVS!!! Fix scaling for 4K users! We hate you!
SiB
Forum Veteran
Forum Veteran
Thu Feb 06, 2020 4:39 pm
You check the new WinBox 3.21 ?
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on ?? ?? 202?
dmayan
Tue May 05, 2020 3:10 am
How you dare to discuss something with Mikrotik devs???? Everything they do is perfect!! /s
Stop this shitshow please, Mikrotik is going down the sink hole
secret
Sun May 10, 2020 1:39 am
I found a solution for this. Execute wine regedit.exe
Browse to HKEY_CURRENT_CONFIG \ Software \ Fonts
Double click LogPixels
Change to Decimal
Increase from 96 to 128, 144 (or larger)
In another terminal, execute wine winbox.exe
The fonts should be bigger
If the menu fonts are small, execute gedit ~/.wine/drive_c/windows/win.ini
Search the [Desktop] section (or add, if it doesn't exist) an add or modify the line with the desired font size in pixels
MenuFontSize = 18
Users browsing this forum: Bing [Bot], Laxity, rusty888 and 38 guests
