antwal
Certificate SSL on RouterOS - Errors / Problems
Mon Jul 21, 2014 8:07 pm
I want import certificate on RouterOS; I have used this command:
/certificate template add name=server country=IT ca-crl-host=<ip address> common-name=<domain name> email=<email>
then I have used:
/certificate create-certificate-request
template: server
key-passphrase: *********
and I have on store 2 files:
certificate-request_key.pem
certificate-request.pem
I have send to CA the content of certificate-request.pem and it send me the response, I have copied the content of certificate to file:
certificate-response.pem
When I try import on RouterOS i receive this error:
[admin@RouterOS] > /certificate import file-name=certificate-response.pem
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
How can resolve this problem?
Thanks.
antwal
Re: Certificate SSL on RouterOS - Errors / Problems
Fri Jul 25, 2014 2:46 am
Resolved with 6.15, but after not working IPv6.
webrgm
Fri Oct 31, 2014 7:33 am
I am using RB1200 with RouterOS 6.19.
I cannot get /certificate template
says:
bad command name template (line 1 column 14)
is there something additional package required to make template working?
Users browsing this forum: No registered users and 108 guests
