Stuntrider
ip cloud rule broblem
Tue Jul 29, 2014 11:47 am
what you need to add a rule in the firewall to work ip cloud. I have a rule in the late drop input and it interferes with the service.
everything new is always fun
npero
Re: ip cloud rule broblem
Tue Jul 29, 2014 12:45 pm
add chain=input comment=Cloud in-interface=WAN_interface protocol=udp src-port=15252
My rule for Cloud, also Normis send me name of server if you want to open all port to cloud server.
Stuntrider
Tue Jul 29, 2014 12:51 pm
does not work
Stuntrider
Tue Jul 29, 2014 12:55 pm
my serial number 444a04378c0a
npero
Tue Jul 29, 2014 1:39 pm
Paste your firewall rules in input chain, that rules tested on five router and working.
Whet disable your input rules in filter it is working ?
normis
Tue Jul 29, 2014 1:50 pm
maybe you have deleted the default firewall rule that allows "established" connections?
Stuntrider
Tue Jul 29, 2014 1:52 pm
yes, if I unplug the rule prohibiting all works
Stuntrider
Tue Jul 29, 2014 1:55 pm
There are 2 rules to permit INPUT and forward passing established connections
Stuntrider
Tue Jul 29, 2014 2:05 pm
here is a screenshot of my firewall
may be something wrong with me?
rextended
Tue Jul 29, 2014 2:44 pm
But Cloud service how works?
CPU -> output -> cloud server -> reply -> same (related/estabilished) connection before -> CPU
or
cloud server -> input -> CPU -> reply -> same (related/estabilished) connection before -> cloud server
Is working on this way, and input chain is not "used"
iprouterboard:port UDP -> output chain -> 81.198.87.240:15252
81.198.87.240:15252 UDP -> related reply -> iprouterboard:port
You do not have any new connection on Input but only estabilished/related.
Firewall Connection Tracking are active?
I'm Italian, not English. Sorry for my imperfect grammar.
normis
Tue Jul 29, 2014 2:50 pm
this:
cloud server makes no connection, the routerboard asks and gets reply in established connection. accepting established should be enough
rextended
Tue Jul 29, 2014 2:52 pm
this:
I do not know if you have reply to my post before I complete it:
81.198.87.240:15252 UDP -> related (estabilished) reply -> iprouterboard:port
Users browsing this forum: No registered users and 118 guests
